Curved monitor and G-sync worth it
Guest
Looking to get a 1440p monitor for a new PC build and was wandering about a couple of things:
01) Is G-Sync worth it (I'm getting a nvidia graphics card). It adds quite the price hike to monitors it seems
02) Does a curve screen make for a better viewing experience (I'm looking for between 27" - 32")
1. no
     why? well freesync now works with nvidia cards so g-sync is almost not worth it at all.
2. not really
curved screens are only useful for ultra-wides
curved panels suffer from poor uniformity, color space and accuracy.
Yes, GSync is worth it. It's more stable than monitors that use Freesync that have been adapted to accept GSync. Well, it's worth it to me.
Is it worth it to you? Only you can answer that. No one can answer that for you. Worth is relative.
Eh, it's decent on bigger monitors, but it wouldn't be a deal breaker for me if it wasn't curved.
38 minutes ago, Saksham said:
1. no
2. not really
Where did you hear about the curved panel issues? I haven't heard any of those complaints before.
Also, you can't use GSync on all FreeSync monitors, and it doesn't always work the way it should. If I'm spending large sums on a monitor, I wouldn't be getting something that "might work, might not, might work but not 100%, YMMV." I'd get something that is guaranteed to work 100%, as it should.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://www.nvidia.com/en-us/geforce/products/g-sync-monitors/specs/
select g-sync compatible in this list. these are all the freesync monitors that have been verified to work with g-sync directly from nvidia.
this list will grow over time.
its not an issue. its just a spec that is worse than flat panels.
so like its not a deal breaker, its just that uniformity and accuracy and stuff like that is not as good as flat panels
Yeah, but look at the ranges of the compatible monitors. That alone would make me get a proper GSync monitor.
no
not worth it
no
that's just stupid
Desktop:
AMD Athlon 64 x2 4600+ (@ 3.00ghz)
ATI Radeon X1950XTX
MSI K9A2 Platinum (ms-7376)
Generic/Unknown PSU (350w)
AMD Phenom Stock CPU Cooler
Philips 107T5 (Will be replaced soon)
1GB Elpida OEM DDR2 (Will be replaced soon)
(our head priest's name is ZUN in all caps)
