daisy-chain all fans?
killzor21
i dont think i have enough air flow through my case so i was wondering if i could some how connect all my fans on to the cpu fan header and use a software to control them all at once. i have an AIO and all i can control fans wise is my GPU fans and my AIO fans which are my exhaust
You can use other fan headers on the motherboard and just dictate that they change speed based on the CPU temp. A single PWM headers can't handle a ton of fans without a powered hub, so getting some fan splitters for multiple fan headers is a better strategy.
Primary PC:
Changing how you control fans won't improve airflow. The two things have very slight correction to each other. There either is airflow or there isn't. How fast fans move air only adds to that. Except in situation where you would have 0rpm mode for intake/exhaust.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
