Need Camera for Photography Class
51 minutes ago, Shreyas1 said:Thanks. I'll probably go with the T2i, but I also found this camera on amazon: https://www.amazon.com/gp/product/B0747TKQQZ/ref=ox_sc_saved_title_1?smid=AAD6EQ1KLLEB6&psc=1
it says in another website that this camera also supports raw, do you know if it's good or not?
Probably wouldn't go for the Lumix. The senslr size on that camera is quite small at 1/2.3". This is compared to the RX100 with a considerably larger 1" form factor sensor, and the T2i's APS-C sensor, which is even larger than that.
A larger sensor (technology being equal) achieves reduced noise in your image, and jmproved dynamic range. This allows you to run the ISO higher before the image degrades significantly. On the flip side however, it makes it more difficult to achieve lots of zoom. The Lumix is a specialty superzoom camera, taking the compromise in sensor size to achieve a far reach.
The Lumix camera also features a slower lens than the rx100 (3.3-6.4 vs 1.8-4.9) You'll probably learn this in class that a lower F-number denotes a faster setting, and the math behind it. At the widest focal lengths however, this means the RX100 is nearly two stops faster than the Lumix, (or 3.2x as much light can enter). In low light conditions, this can prove useful.
The kit lens for the T2i probably won't be particularly fast either, though the lens can be changed out as you learn, and you can also safely run the ISO a bit higher if necessary. Additionally, the hot shoe allows easy use of flashes. Having control of lighting is an extremely valuable thing.
