Base 64 decode
Solved by Sauron,
You're always decoding the same value since you always pass $content to the function. Try this
<?php $input = file_get_contents("b64.txt"); $x = 0; while($x < 50) { $input = base64_decode ($input); $x++; } echo $input; ?>
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
