CPU Fan and RAM Clearance
smokedoff
Go to solution Solved by Stormseeker9,
20 minutes ago, smokedoff said:
Intel Core i5-9400F
No I'm just checking if everything is okay before I order the parts
I'm in lebanon, https://pcandparts.com/ is where I'm going to order my parts from
Something to consider instead of 9400f. Left storage/cases/gpu out. Psu is questionable but from what I saw was available on the website this I suppose would be the best choice. Don’t jnow anything about aerocool and the Thermaltake models listed there I believe belong to the same tier as this one
So I wanted to order some parts online for a kinda budget gaming pc build but I wasn't too sure if I have enough CPU Fan and Ram Clearance..
it's my first build and I'm limited with the parts available in my country so I think this is the best budget cooler I could find that I think should fit easily but I need to be 100% sure before I make the purchase!
Mobo: MSI MPG Z390 GAMING PLUS
Cpu Cooler: ThermalTake CL-P022-AL12RE-A Riing Silent 12 CPU Cooler
Ram: Adata XPG Gammix D10 8GB (1 x 8GB) DDR4 3000 (I'll buy another one later so it'll be 2x8GB)
Case: NZXT H500i CA-H500W-BR Smart Case Matte Black+Red
Thanks for your time!
What cpu are you trying too cool? Have you purchased anything yet or not? What is location?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
8 minutes ago, smokedoff said:
 MoboMSI MPG Z390 GAMING PLUS
Budget build? And you get a 9th gen CPU? And a z390 board?
Budget build for 9th  Gen CPU? z390mobo? and NZXT??????
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
Budget build yet you're buying an overpriced Z390 board?? What.
All should fit fine. But if you link to stores available, we can check other options.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Guys I'm not willing to build a very cheap ugly pc, I want it to look cool and kind of future proof for a maximum of $1000, ll be using the Intel Core i5-9400F.. as for the mobo I wasn't sure what to pick so I picked one that matches the build (as I went with the black and red nzxt h500i case) and checked for compatibility and everything was fine, you could be kind and suggest another mobo instead of mocking!
Intel Core i5-9400F
Me: I need to redefine budget build, Im missing something lol
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
Intel Core i5-9400F
Thanks man I’ll take this into consideration, it’s my first build and I wasn’t really sure what parts to pick.. I appreciate that!!
You can add a second stick of ram to your build. Was just leaving enough breathing space to look what GPU you want etc.
no worrries !
