[HELP] My first attempt at a build and it is not working
Solved by VEXICUS,
7 hours ago, _se7en said:@PopsicleHustler @badreg @fasauceome Installed the GPU and shorted the motherboard as described below.
What can I try next?
These pins are to clear the cmos.
This is the page you should be looking at...
Featured Topics
3
1
JFRStudent ·
Posted in Photography and Videography1 -
5
6
amir2927 ·
Posted in CPUs, Motherboards, and Memory8 -
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
