How to Coax? ?
3 hours ago, Cavalry Canuck said:
So what exactly is the difference between cable and terrestrial television?
And what is with the need for a Cable Box in every room? How would that work? When I had “cable tv” I just plugged the tv into the coax port in the wall and had access to every channel. Is it still just a matter of splitting runs from the signal source (be it satellite, cable, etc), but the box interprets the signal and establishes the channel; or, does each box need a dedicated, un-split run from the signal source?
As to having the cable company guy come do it, that’s difficult to arrange with my work schedule. That and I don’t need to be paying for extra labour. My house is old enough that every time I open a wall up, there is a new surprise waiting for me. I’d hate for one of those (and the associated expense) to befall the poor cable guy. I’d likely run them all adjacent to my CAT 6 runs anyway, which is part of what prompted this question. If I am to do the Coax, I’d rather do it at the same time as the ethernet, rather than tearing into everything twice.
Regardless of your thoughts on if I should, it’s something I’d like to do. I appreciate that you gave me perspective on where I need to start.
To answer the first question the cable co provides one and the other one is provided by an antenna in your home or just outside your home. Cable boxes are needed because most providers use digital cable so they can encrypt the channels. So that’s why a cable box is needed.
Splitting is is a bit more complicated due to how cable internet works. Cable modems require the best signal possible so you can’t split the signal to them very much. Generally a two way splitter is the first splitter used on the line. One side feeds the modem and the other feeds a TV or another splitter. Each splitter creates loss, so you don’t want to use too many.
Another use use for coax is MOCA. This kinda treats the coax as Ethernet. But it’s not as good as Ethernet and setup is a bit more involved. Bonded MOCA 2.0 adapters can do up to about 800 Mbps. But like wireless they only communicate one direction at a time. They are used when Ethernet is not an option. BUT cable providers use MOCA for whole home DVR setups. MOCA can coexist with cable signal as well as over the air tv. As it uses the upper bands on the coax.
