I've had my 2080ti since about april now, and for the most part its been fine. I got more fps than what i would with a 1050ti and was pretty happy with it, haven't tried playing gta till 2 nights ago, and since then my experience has been horrible. I can't reach 100fps no matter what settings or res. I play 1080p which I know is what the 2080TI is not intended for. I'm planning on getting a 1440p monitor soon, but until then I use a custom 2650x1440 resolution in the nvidia control panel, and it works perfectly (boosted my Fortnite fps from 70 on low settings to 380 on low) and it works fine with other games, I tried that with gta and nothing changed, I tried dsr X4 on 1080p and nothing changed and I can't see the problem. It may be my ram as a stick got damaged and no longer works so I am left with 8GB, but even with 8GB my 1050ti gets more frames. any help would be appreciated.
I'll link a video soon of my settings and monitoring software, but I can confirm the GPU sits a around 40-50c and only 40% usage and the cpu around 50-60 at about 40-50 usage.
Specs:
MSI Trio RTX 2080TI
Intel I7-8700K - Kraken x62 water cooled
HyperX Fury 16gb - only 8gb working
https://linustechtips.com/topic/1085519-extremely-low-2080ti-performance/
Did you DDU in safe mode and reinstalled the nvidia drivers fresh new when you replaced the 1050 Ti for the 2080 Ti?
Personal Desktop":
Luna, the temporary Desktop:
On 7/24/2019 at 3:58 AM, bignaz said:
Download gpuz run a game or benchmark or something with the sensors tab open. You can enable logging if you want. Then check out what your clocks were going to perfcap, gpu load, core voltage etc.
I logged it to my computer after playing one mission on gta v. I'll leave the txt file here
GPU-Z Sensor Log.txt
Specs:
MSI Trio RTX 2080TI
Maybe you did not plug in the GPU on the top PCI-E slot? Or it may be a driver problem. Also check your power cables to the GPU.
CPU: AMD Ryzen 7 2700X; GPU: MSI RTX 2060 Gaming Z; MoBo: MSI B450 Gaming Plus ATX; RAM: TForce Delta TUF RGB 3200MHz (2x8) 16GB;
Case: CoolerMaster MB511 RGB TG; PSU: Seasonic Prime FX Gold 750W Fully Modular; CPU Cooling: Cooler Master MA620P; Storage: WD Blue 250GB SATA SSD & Seagate Barracuda 2TB 7200RPM; Monitor: MSI MAG241C 144Hz Curved Gaming Panel; Keyboard: Corsair K95 RGB Platinum (MX Brown); Mouse: Fantech X11 Daredevil
Specs:
MSI Trio RTX 2080TI
Reinstall GTA V.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
Run the game with MSI Afterburner and study the power % graph afterwards.
I think your card has a 110% power limit. Check to make sure it is reaching that limit.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
GPU has been int eh top slot, all cables are connected correctly, and did a fresh DDU today.
I have my power limit to 110%. like always, it only reaches 40-50% on 1440p
My i7 8700k could only do 77% at 1440p and 71% at 1080p. It could do better if I removed the anti aliasing but that is not good option.  I replacing the i7 8700k with a i7 8086k and the card can run in the hundreds.
A day or two ago I did some tests with Assassin's Creed Odyssey and found that at 1440p ultra high settings my 2080 ti is bottlenecked by my CPU so it can only reach 124% on the power limit. With the same settings but with low anti aliasing the card will reach its power limit of 130%. My conclusion is that today's high end CPUs are just barely capable running a 2080 ti and I am hoping next gen will do better.
Can you overclock your i7 8700k to 5ghz? The seems to be the magic number for minimizing bottlenecking at lower resolutions with a 2080 ti.
How would I do so safely? I have a NZXT kraken x62 cooler, Asus rog strix z370-e gaming, and a corsair 650w PSU.
Your 2080 ti uses a lot of power and with a overclocked CPU you are not going to have not much left. I only recommend 850 watts and up mainly because I don't want the PSU working to hard.
I would look for a YouTube overclocking video with your motherboard and CPU. Most tutural videos are for 5ghz on the i7 8700k so one should be easy to find.
Since I use a Maximus Hero X board I used the der8auer video. I have refined it by watching other videos but I started with this one.
I would have to disagree. He is only using 450 to 500 watts if everything is overclocked to the max. 650w is fine.
My FTW3 Ultra 2080 ti overclocked sometimes uses up to 385 watts. My i7 8086k overclock uses about 200 watts. That = 585 watts.
As I said.  I don't want the PSU working to hard.
Power draw is a lot lower when you don't have 130%+ power limit though.
4K // R5 3600 // RTX2080Ti
Yes. A lot lower.
Here is what I get with GPU-Z.
Look you really need to go away and do some research because a 2080ti bottlenecked at 1440p in assasins creed oddesy with ultra settings
Ur judging ur cards performance off of it reaching the power limit? Why? Ur card can run 100 percent utilisation without hitting power limit, u could very well be voltage limited
U can't say ur card is CPU bottlenecked because it only reaches 124 percent powerlimit
My card never hits power limit but still 100 percent load on the card
You need to get msi afterburner then watch a lot more tutorials on what all the different meanings read because ur spurting loads of bs basically and confusing people
Ur claiming huge gains from swapping to a 8086k from a 8700k but there the same CPU with small frequency difference
This it's self speaks volumes about ur knowledge
-14900kf
- 4000 32gb ram
-4070ti super duper
Here is ACO at ultra. Any bottlenecking I get is caused by high anti aliasing setting at ultra. I can remove the bottleneck by lowering it.
Gains are there with a i7 8700k at 5ghz as well.
My i7 8700k could not make it to 5ghz.
The next big jump in performance is at 5.3ghz. 5.1 anand 5.2 seem to be a bit of a waist.
