Best CPU for RTX 2070
Solved by KyrusDLT,
On 7/15/2019 at 5:58 PM, StarsMars said:I know I had some weird issues with gta and other games when windows 10 creators update came out.
What version are you running?
On 7/15/2019 at 2:27 PM, WereCat said:looks normal
get cpuz and check your voltages and clocks under load
Thanks for the help, I really appreciate the fact that you stopped me from getting a new CPU. The issue was not Windows, the issue was actually the cooler. I upgraded, again, to a different cooler and temps go perfect. Games now go smooth at max graphics and the cpu doesn't heat up. Thanks for the help!
