No signal on monitor
MrN0th1n
Today i got myself a new pc with a monitor AOC G2460VQ6.
The problem was that i couldn't get a signal on the monitor. I tried D-SUB, HDMI and DP but none of them worked tried putting the hdmi and dp into gpu but that also didn't work. Tried unplugging and re-plugging. Pc turned on just fine and the monitor as well but displays no signal.
The pc specs are:
Cpu: Intel Core i5 9400F 2,9G
RAM: DDR4 8GB 2400MHz
Motherboard: Gigabyte B360
GPU: 6GB Gigabyte GTX1660TI
SSD: 240GB
HDD: 1TB
Powersupply: PSU 500W
Plug the DP cable into the monitor and then into the GPU on the computer not the motherboard. Turn the monitor on, open the menu on the monitor make sure to select DP as your input, then turn on the PC.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z690 Aorus Elite AX DDR4 | GPU - ASUS TUF Gaming OC RTX 4090 RAM - Corsair Vengeance Pro RGB 64GB 3600mhz | AIO - H150i Pro XT | PSU - Corsair RM1000X | Case - Phanteks P500A Digital - White | Storage - Samsung 970 Pro M.2 NVME SSD 512GB / Sabrent Rocket 1TB Nvme / Samsung 860 Evo Pro 500GB / Samsung 970 EVO Plus 2tb Nvme / Samsung 870 QVO 4TB  |
TV Streaming PC: Intel Nuc CPU - i7 8th Gen | RAM - 16GB DDR4 2666mhz | Storage - 256GB WD Black M.2 NVME SSD |
Phone: Samsung Galaxy Z Fold 4 - Phantom Black 512GB |
Have already done that. Seems like nothing is working
  • 1 month later...
fixx????
