Need suggestion for WiFi router with around 50m - 100m coverage
40 minutes ago, Cheezey said:By the way, any recommended router for the case above?
Your ISP doesn't come with one?
Otherwise, any decent router will do. If you want to keep with the UniFi world, the USG is pretty solid. There's also the Edgerouter X (budget), Edgerouter Lite, and the overkill Edgerouter 4.
You will need a network switch with the dedicated routers above though, but they're pretty cheap, Netgear GS105 or 108 switches will work plenty fine.
It would be like this:
ISP Modem -> Router -> Switch -> UniFi APs
The switch can also handle whatever ethernet wired devices you have in the office (If you have any)
Also, if possible, i would place the APs diagonally (one in the bottom left corner of your drawing, the other in the top right)
