HELP!
Go to solution Solved by ManosMax13,
1 minute ago, ComputerNerdDude158 said:
Does your ceiling not fall off sometimes? It happens to me like once a week
Go to sleep you might be drunk or high.
do you live in space or your house built upside down? I have never heard of dropping things scratch the celing.
Desktop benching:
https://linustechtips.com/topic/1066554-help/#findComment-12592304
Just now, ComputerNerdDude158 said:
No, I mean the ceiling that is down!
celing is the inside facing side of the roof, so you mean the floor?
Depends on the floor's material.
Desktop benching:
https://linustechtips.com/topic/1066554-help/#findComment-12592309
*visible confusion*
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1066554-help/#findComment-12592319
Just now, ManosMax13 said:
How did the ceilling fell off.
It's a joke
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1066554-help/#findComment-12592322
*visible relief*
https://linustechtips.com/topic/1066554-help/#findComment-12592324
is that a tent?
Desktop benching:
https://linustechtips.com/topic/1066554-help/#findComment-12592332
-Topic Locked-
On 8/27/2018 at 5:44 PM, Whiskers said:
Community Standards
  • No trolling or flame-bait.
https://linustechtips.com/topic/1066554-help/#findComment-12592443
Guest
