PCPartPicker Part List
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($238.00 @ Shopping Express)
Motherboard: ASRock - B450M Steel Legend Micro ATX AM4 Motherboard  ($145.00 @ PLE Computers)
Memory: Team - T-Force Delta RGB 16 GB (2 x 8 GB) DDR4-3000 Memory  ($147.00 @ Skycomp Technology)
Storage: Kingston - A400 240 GB M.2-2280 Solid State Drive  ($46.00 @ Mwave Australia)
Storage: Seagate - Constellation ES.2 2 TB 3.5" 7200RPM Internal Hard Drive  ($45.38 @ Amazon Australia)
Video Card: Sapphire - Radeon VII 16 GB Video Card  ($1049.00 @ Mwave Australia)
Case: Inwin - 301 White MicroATX Mini Tower Case  ($89.00 @ BudgetPC)
Power Supply: Gigabyte - 750 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($109.00 @ Mwave Australia)
Case Fan: Corsair - HD120 RGB 54.4 CFM 120mm Fan  ($28.00 @ Umart)
Monitor: AOC - C24G1 24.0" 1920x1080 144 Hz Monitor  ($278.00 @ Shopping Express)
Keyboard: Razer - BlackWidow X Chroma Mercury Edition Wired Gaming Keyboard  ($165.00 @ PC Byte)
Mouse: SteelSeries - Rival 100 Wired Optical Mouse  ($58.00 @ I-Tech)
Headphones: Corsair - VOID PRO RGB (White/Black) 7.1 Channel  Headset  ($127.10 @ Amazon Australia)
Speakers: Logitech - LS21 7 W 2.1ch Speakers  ($150.29 @ Amazon Australia)
Total: $2702.77
Generated by PCPartPicker 2019-05-08 21:36 AEST+1000
more RGB and includes fans. mATX formfactor.  also closer to budget. and Radeon 7.
https://linustechtips.com/topic/1062063-i-need-help/page/2/#findComment-12549556
I wouldn't go with a Patriot Burst, seems those drives have issues.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1062063-i-need-help/page/2/#findComment-12549600
CPU Cooler: ARCTIC - Freezer 34 eSports DUO CPU Cooler  ($63.54 @ Amazon Australia)
Motherboard: ASRock - B450 Steel Legend ATX AM4 Motherboard  ($171.44 @ Amazon Australia)
Memory: Corsair - Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-2666 Memory  ($163.64 @ Amazon Australia)
Video Card: Sapphire - Radeon RX VEGA 64 8 GB NITRO+ Video Card  ($663.21 @ Newegg Australia)
Case: NZXT - H500 (White) ATX Mid Tower Case  ($122.00 @ Skycomp Technology)
Power Supply: be quiet! - Pure Power 11 600 W 80+ Gold Certified ATX Power Supply  ($119.00 @ PCCaseGear)
Case Fan: Thermaltake - Riing 12 RGB Triple Pack 40.6 CFM 120mm Fans  ($74.00 @ Shopping Express)
Monitor: MSI - Optix MAG241C 23.6" 1920x1080 144 Hz Monitor  ($329.00 @ Austin Computers)
Mouse: Razer - Lanchead Tournament Edition Mercury Wired Optical Mouse  ($107.10 @ Austin Computers)
Headphones: Corsair - HS70  7.1 Channel  Headset  ($136.30 @ Newegg Australia)
Total: $2593.90
Generated by PCPartPicker 2019-05-08 21:00 AEST+1000
improved upone the build and made the style a littl emore fitting to a white style build.
and there were some misstakes like the PSU. otherwise it was fine.
I would use a different cooler like this one from Cooler Master:  https://www.coolermaster.com/catalog/coolers/cpu-air-coolers/masterair-ma610p/
https://linustechtips.com/topic/1062063-i-need-help/page/2/#findComment-12552102
1) Also, use the MSI B450 Tomahawk. It is a much better board, for just a small price bump.
2) I would suggest using an RTX 2060, or a GTX 1660Ti for that CPU, as the Vega 64 is not worth it, and there is a very slight chance of bottlenecking the CPU
3) Over H500, I would select the Corsair Spec 06 RGB, which is better for airflow, aesthetics, and fan compatibility.
4) The Thermaltake fans would need a separate controller, that would communicate with the motherboard, using usb. Instead, go for deepcool"s CF120 RGB fans. they communicate using a 5V ARGB port, and are cheaper.
5) The PSU is not worth the cost. Instead, go for the CX650M from Corsair. It is Semi Modular, and you'll save some bucks.
6) The Razer Lancehead? Seriously? ( Go for the G403, or the Pulsefire Surge if you want an ambidextrous mouse)
7) The Monitor is not worth the money. Go for an LG monitor or an Acer monitor with the same specs.
8= The Seagate drive you mentioned is an enterprise drive, and is significantly slow. Go for a 2TB Barracuda instead.
https://linustechtips.com/topic/1062063-i-need-help/page/2/#findComment-12552117
why? the Freezer 33/34 duo is excellent
this is literraly bull in relation to GPUs. the gtx 1660ti is orders of magnitude slow than the vega 64. and the RTX 2060 is slightly slower and has less Vram than the Vega 64. with current pricing the vega 64 is worth it. you must be running by mining graze pricing 9 months ago.
fan compatibility.
what? there is literally standardized fansizes........
CXM is bad electrically and the market you dont save a whole lot in this regard. dont go for bad PSUs.
did you do price comparisons? because that there is not very relevant unless you have something to suggest.
also AOC was the cheapest same panel monitor.
its 7200RPM and has the same ammount of cache.......... its just as fast and you save money on it.......
got mentioned earlyier and i adressed it. i was going for style points without sacrifising much VRM. also updated to an mATX build later with the Radeon 7.
dont you mean bottlenecking the GPU?
also bottlenecking is fearmingering and is an irrelevant metric that only propegates fear and worry among PC buyers
https://linustechtips.com/topic/1062063-i-need-help/page/2/#findComment-12552156
ehm... why?
not that big, but i kinda agree. asrock has some solid on b450 tho
bottlenecking isn't going to make it worse than buying something worse. and fyi: it won't bottleneck in most games
that'll whine the crap out of that machine, and performs electrically much worse, has a worse sleeve fan, things like that
it's the same rotation speed and cache...
https://linustechtips.com/topic/1062063-i-need-help/page/2/#findComment-12552168
Motherboard: MSI - B450-A PRO ATX AM4 Motherboard  ($141.00 @ Skycomp Technology)
Storage: Intel - 660p Series 512 GB M.2-2280 Solid State Drive  ($96.91 @ Amazon Australia)
Storage: Toshiba - P300 2 TB 3.5" 7200RPM Internal Hard Drive  ($69.00 @ BudgetPC)
Video Card: Gigabyte - GeForce RTX 2080 8 GB WINDFORCE Video Card  ($999.00 @ Shopping Express)
Case: Corsair - Carbide SPEC-06 ATX Mid Tower Case  ($109.00 @ PC Byte)
Power Supply: Gigabyte - 750 W 80+ Gold Certified Semi-modular ATX Power Supply  ($109.00 @ Mwave Australia)
Monitor: ViewSonic - VX2758-C-MH 27.0" 1920x1080 144 Hz Monitor  ($269.00 @ BudgetPC)
Speakers: Logitech - Z313 25 W 2.1 Channel Speakers  ($49.00 @ Mighty Ape)
Total: $2635.31
Generated by PCPartPicker 2019-05-09 17:12 AEST+1000
https://linustechtips.com/topic/1062063-i-need-help/page/2/#findComment-12552208
The MA610P is 166.5mm tall, which wont fit in any of the cases listed so far.
https://linustechtips.com/topic/1062063-i-need-help/page/2/#findComment-12552670
The Pure Power 11 is still uses a forward technology so if your worried about coil whine I'll avoid that one too.
They, Corsair CXM and pure power 11, actually perform electrically similarly according to reviews by Aris.
It doesn't use a sleeve bearing fan...
https://linustechtips.com/topic/1062063-i-need-help/page/2/#findComment-12553939
