Just now, AVSHedgehog said:
Is it all fine tho?
PCPartPicker Part List
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($238.00 @ Shopping Express)
CPU Cooler: ARCTIC - Freezer 34 eSports DUO CPU Cooler  ($63.54 @ Amazon Australia)
Motherboard: ASRock - B450 Steel Legend ATX AM4 Motherboard  ($171.44 @ Amazon Australia)
Memory: Corsair - Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-2666 Memory  ($163.64 @ Amazon Australia)
Storage: Kingston - A400 240 GB M.2-2280 Solid State Drive  ($46.00 @ Mwave Australia)
Storage: Seagate - Constellation ES.2 2 TB 3.5" 7200RPM Internal Hard Drive  ($45.38 @ Amazon Australia)
Video Card: Sapphire - Radeon RX VEGA 64 8 GB NITRO+ Video Card  ($663.21 @ Newegg Australia)
Case: NZXT - H500 (White) ATX Mid Tower Case  ($122.00 @ Skycomp Technology)
Power Supply: be quiet! - Pure Power 11 600 W 80+ Gold Certified ATX Power Supply  ($119.00 @ PCCaseGear)
Case Fan: Thermaltake - Riing 12 RGB Triple Pack 40.6 CFM 120mm Fans  ($74.00 @ Shopping Express)
Monitor: MSI - Optix MAG241C 23.6" 1920x1080 144 Hz Monitor  ($329.00 @ Austin Computers)
Keyboard: Razer - BlackWidow X Chroma Mercury Edition Wired Gaming Keyboard  ($165.00 @ PC Byte)
Mouse: Razer - Lanchead Tournament Edition Mercury Wired Optical Mouse  ($107.10 @ Austin Computers)
Headphones: Corsair - HS70  7.1 Channel  Headset  ($136.30 @ Newegg Australia)
Speakers: Logitech - LS21 7 W 2.1ch Speakers  ($150.29 @ Amazon Australia)
Total: $2593.90
Generated by PCPartPicker 2019-05-08 21:00 AEST+1000
improved upone the build and made the style a littl emore fitting to a white style build.
and there were some misstakes like the PSU. otherwise it was fine.
https://linustechtips.com/topic/1062063-i-need-help/#findComment-12549489
17 minutes ago, Sharvaj Ingawale said:
@GoldenLag I saw the build. the link for PCPartPicker worked fine. Its got a Ryzen 5 1600X with a MSI RX 580
17 minutes ago, GoldenLag said:
no problem, but posting the link would be quite handy. or editing it into the original post
nvm
Thank you
https://linustechtips.com/topic/1062063-i-need-help/#findComment-12549501
Memory: Corsair - Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3000 Memory  ($171.59 @ Amazon Australia)
Total: $2601.85
Generated by PCPartPicker 2019-05-08 21:07 AEST+1000
there we go. Ramspeed wasnt up to par. if you want to save a couple of $
https://au.pcpartpicker.com/product/mM8j4D/team-t-force-delta-rgb-16gb-2-x-8gb-ddr4-3000-memory-tf4d416g3000hc16cdc01
buy this ram instead.
https://linustechtips.com/topic/1062063-i-need-help/#findComment-12549505
1 minute ago, AVSHedgehog said:
what
i  just noticed a minor issue, nothing huge.
i would also suggest looking towards logitech for mouse peripheral, though i will leave that to you as peripherals can be very much be a personal taste.
also perhaps  create a post in audio section on the forum asking for the best headset within x and x price. remember to give pricing in native currency and your country.
https://linustechtips.com/topic/1062063-i-need-help/#findComment-12549507
Motherboard: MSI - B450M MORTAR TITANIUM Micro ATX AM4 Motherboard  ($140.00 @ Umart)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($130.28 @ Amazon Australia)
Storage: *Seagate - Constellation ES.2 2 TB 3.5" 7200RPM Internal Hard Drive  ($45.38 @ Amazon Australia)
Video Card: Sapphire - Radeon VII 16 GB Video Card  ($1049.00 @ Mwave Australia)
Case: Corsair - Air 240 MicroATX Mid Tower Case  ($123.00 @ Austin Computers)
Power Supply: Gigabyte - 750 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($109.00 @ Mwave Australia)
Mouse: SteelSeries - Rival 100 Wired Optical Mouse  ($58.00 @ I-Tech)
Headphones: Corsair - VOID PRO RGB (White/Black) 7.1 Channel  Headset  ($127.10 @ Amazon Australia)
Total: $2710.05
Generated by PCPartPicker 2019-05-08 21:19 AEST+1000
small iteration to actually have a case that is made for mATX.
https://linustechtips.com/topic/1062063-i-need-help/#findComment-12549527
