Hello everyone!!
I wanted to drop a thing that I realized a few days ago. I've a Pentium G4560 with a SSD Kingston V300 (old as fuck, I know) and a Ryzen 7 1700 with a M.2. Samsung 970 EVO PLUS.
The funny story is that the Intel+SSD, being way cheaper, older and worse in general boots and shuts Windows FASTER than the Ryzen+M.2. That thing triggers the shit out of me. How is it freaking possible? Might it be a Mobo config?
PS: the M.2. works perfectly. I've CrystalMark it and the numbers are perfect and also I tried with my old M.2. a XPG GAMMIX S11 and the same thing goes: a slower boot than the Intel
PSS: Intel MB:: MSI H110i PRO ----- AMD MB: MSI B450M MORTAR
https://linustechtips.com/topic/1059671-intelssd-faster-than-amdm2/
boot process is mostly SSD dependent, but other factors like files you have on the OS and the motherboard BIOS's work time also affects it.
Desktop benching:
This is not exactly rare, nvme drives aren't eye wateringly faster than SATA SSDs like SSDs in general are over hard drives, if you've got more programs running off the NVMe SSD then of course it takes more work and time to shut down.
Primary PC:
PSU tier list
How many watts do I need?
Both computer are just now with fresh Windows 10 installation. So that's not the issue here for the moment
Other things besides raw boot drive throughput would be a factor here. In terms of actually FEELING the speed M.2's are actually not much greater than SSDs (At least when it comes to boot times, loading applications, installing things, etc) while on newer hardware it may be necessary for the BIOS/Windows to initialize more hardware features on startup causing bootup to take longer. A better comparison would be similar gen hardware with similar functions on both boards. Or better test the SSD and M.2 on the same system and compare the difference. You need very particular workloads to really see the benefit of using NVMe storage.
That's the thing: I just tested the XPG (which was insanely fast boot on the Intel) in the AMD and it boots/shuts slower. That's what is driving me crazy xD
My 1600 takes much longer at POST than my 8700k system.
Probably motherboard is just crappy or just RAM retraining or some crap.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
Who cares? You're not waiting 4 minutes for an HDD to boot. Does an extra 3 seconds really matter?
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
It's the oppossite. The Intel system has a basic 1x8Gb Kingston 2133Mhz with a basic Mobo. The AMD has a much beter Mobo with 2x8Gb XPG SPECTRIX D41 3000Mhz.
And yes, is with the AMD system that everything goes slower
It doesn't. BUUUUT, after having a newer and more expensive PC and seeing this......I can't help to just get freaking mad about it ^^'
I was just talking about my scenario, but my undertanding is that AMD POST tends to take longer
The ASUS X470 Prime Pro takes seconds to POST and then boot to Windows.  The ASUS X470 Crosshair VII takes many many times longer to POST and boot.
What I am saying is that it isn't as simple as you might think.  My laptop POSTs and boots faster than either of those above mentioned boards.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
So it might be a MOBO thing? But what about the other side? What about shuting down the computer? There the Mobo shouldn't matter at all.....
In my experience, quirky behavior has almost always been motherboard related
What are your boot and shutdown times?
Black Knight-
Daughter's Rig;
my MSI B450I with 64GB Samsung 830 and 2400G with DDR4-2400 boots faster than Ryzen 7/1700x on ASUS X370-F Strix with DDR4-3200.
So what??
Change the SSDs and see what happens.
"Hell is full of good meanings, but Heaven is full of good works"
So what??
I've tested with both M.2. that I've. Same boot/shut times. So it must be something related with Hardware, but not an issue
Once you've got all your OC and RAM dialed in change it to "Fast Boot" or "Ultra Fast Boot".
It helped tremendously on my 1600, but be warned that it prevents you from easily accessing BIOS at startup on UltraFastBoot. You will need to shutdown -> troubleshoot -> UEFI to get back in. Which is a problem if you can't get into windows or windows isn't working properly.
I notice this as well.
No, we aren't using the same PC's.  Pluto copied my setup. /s :)
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Hell I was happy when switching from the shitty marvel USB3 to USB2 cut my boot time in half to 33 seconds. I love my X58, but would love native M.2.
Black Knight-
Daughter's Rig;
