Noctua nh-d15 vs be quiet 360 loop
ZEEF
Hi! (Not sure if posted in the right forum & I'm sorry if it isn't!)
I'm currently running a "noctua nh-d15" on a i7-4770k OC'ed to 4.5Ghz, and while i like the coolor and the temps i really don't like the sound level.
I'm just about to upgrade basicly everything in my PC and i was looking at the "Be quiet 360 loop" as my new cooler but i really down wanna downgrade cooler just to lower the noise level, so i was wondering if anyone here knows how the 2 coolers perform compared to each other? :)
(The reason I'm going with a 360 loop is because i was kinda hoping for even better cooling and i chose be quiet because of the sound level and because i don't want any RGB stuff)
You should just keep the Noctua nh-d15 and just change the fans, to the relatively new Corsair ML (magnetic levitation)
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
0.o
The NH-D15 should be plenty for cooling and very quiet.
What rpm are you running the fans at and what are your temps? What core voltage are you using for the cpu? Have you tried lowering fan speeds?
I don't really wanna lower my fan speeds, i want maximum cooling with as little sound as possible, which is why i was looking at the "be quiet 360 loop"
& why i was wondering how the 2 coolers compare in cooling performance.
Quiet fans and coolers are generally meant to be run at low rpm but have more cooling headroom when needed. The same fans are generally not very quiet at max rpm.
The Silent Loop 360 performs a bit better than the NH-D15 and may be a bit quieter or noisier depending on the performance you're trying to hit. It isn't significantly quieter if you're maintaining the same cooling performance though. https://www.guru3d.com/articles_pages/be_quiet_silent_loop_360_review,9.html
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
Its also down to your layout as apparently the Noctua is much louder in pull configuration than push.
It could also be a mismatch between your rear case fan and the cooler fans, depending on how close they are to each other.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
