SSD Buying Advice ---> Technical help <---
Go to solution Solved by minibois,
1 minute ago, shanky298 said:
But these adapters exist, the reason for which I can't understand.
Just checked out the link and it says it only supports M.2 SATA SSD's (and mSATA SSD's), not sure why it says it supports M key drives though.
If you have an M.2 slot in your laptop, just get an M.2 SATA SSD. otherwise just get a normal 2.5" drive IMO
Hello,
Greetings from India!!
---> Noob Alert <---
I am planning to buy Samsung's PM981 512GB NVME SSD to be used in a laptop that only supports SATA 3 drives but I stumbled upon this adapter here which takes an M.2 SSD and gives SATA 3 as out interface.
Doubt ( Since I don't have enough knowledge): Will Samsung's PM981 drive work in a SATA 3 supported laptop if the aforementioned adapter or any other made  M key supported adapter is used??
Thanks!!
https://linustechtips.com/topic/1044339-ssd-buying-advice-technical-help/
I didn't check the link, but just understand that if a drive uses a PCIE interface, you can't just simply convert it to a SATA interface; even though they both could use an M.2 connector.
Basically what I am saying is; the connector doesn't matter, it's the interface that matters which is totally different in this case.
While I can't guarantee you it won't work, I am pretty sure it won't because it uses a different interface.
But these adapters exist, I can't understand why ?
Why not just get a SATA 3 SSD instead? Even assuming this shady chinese adapter works, you won't benefit at all from the faster NVME by using such adapter, you'd be limited by SATA 3, meaning there's literally no point to it in the first place.
Just buy a SATA 2.5" SSD. I recommend WD Blue or Inland Professional, depending on how much you're willing to spend (WD is nicer, but more expensive).
NVMe drives are more expensive, so if you're not even putting it in an NVMe slot, the extra cost is definitely not worth it.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
Absolutely valid point!! thing is I might change my laptop to a something newer that has M.2 interface, in that case, I will be able to use PM981 drive natively.
Currently using Samsung's 850 Evo
Then why bother upgrading?
NVMe isn't any faster for regular use. I have a SATA SSD in my desktop and an NVMe SSD in my laptop; they both boot and load fully to the Windows desktop within seconds of each other. Not to mention, the game load times on the drives are practically identical... imo the 960 EVO in my laptop wasn't worth it; I could have gotten a 1TB WD Blue M.2 for less than what I paid for this 500GB NVMe....
*GPU Test Bench*
Got it, going for PM981 at this point ( unless I upgrade to something newer ) would be a complete waste of money.
m.2 is a connector
NVME/PCIe is a interface
Sata 3 is also an interface.
m.2 connector can have either/or.
edit: sort of similar to how USB Type C can be 3.0 or 2.0 or many other protocols like Thunderbolt or Displayport.
scam? Because you can get PCIe lanes and change that to SATA, not the other way around. You can at most use SATA M.2 SSD with the adapter.
Desktop benching:
Absolutely valid point!! thins is I might change my laptop to a something newer that has M.2 interface, in that case, I will be able to use PM981 drive natively.
So you don't need this thing just yet. You already have a good SSD. There's no point buying the NVME drive today when you don't have the new laptop to put it in.
Unless you're literally planning to get a new laptop within the next month or two, I wouldn't recommend buying an NVME drive that you don't need/can't use since the price will likely keep going down before you get said new laptop.
Plus the fact that the adapter, like minibois said, is not for M.2 NVME drives, it's for M.2 SATA or mSATA, hence why this adapter wouldn't work in the first place for your usage.
