Im building a budget pc for <€600 with thse parts, but dont know which case to choose.
PCPartPicker part list:
Total: $583.71 (in dollars but euro price is about the same)any recommendationsfor a budget case?
https://linustechtips.com/topic/1043645-case-help/
whats your budget for a case?
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1043645-case-help/#findComment-12385529
Fractal Design Focus G is fairly cheap and OK to build in. The Corsair 100R is OK as well, but has horrible cable management.
Also:
You want 3000Mhz RAM at a minimum (look for G.Skill Aegis), Ryzen, especially first gen, benefits greatly from fast memory.
That SSD is a poor deal. Look up the Inland SSDs, for $3 more you could have 500GB (or for ~$20 less you could stay with 250GB). They are Micro Center's brand, and they are good SSDs; I have used these many times.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1043645-case-help/#findComment-12385538
if you want a higher quality case you should find a slightly cheaper graphics card and sacrifice a little performance for quality or use these
https://pcpartpicker.com/product/2tTrxr/corsair-spec-04-blackred-atx-mid-tower-case-cc-9011107-ww
https://pcpartpicker.com/product/7HYXsY/raidmax-case-atx403wb
NOTE: I AM NEVER ALWAYS RIGHT, BUT I AM HAPPY TO HELP ANYWAY I CAN
Tag me @WambleCropped or quote me so I can see your reply
My Rig: RTX 2060, R7 1700X, Samsung 860 500GB, Masterlite Liquid Cooler, Asrock Pro B540,16GB of RAM G.Skill 2133
PSU Tier List                    SSD Tier List                              Graphics Tier List
https://linustechtips.com/topic/1043645-case-help/#findComment-12385586
Type Item Price
Motherboard MSI - B350M PRO-VD PLUS Micro ATX AM4 Motherboard $64.99 @ B&H
Total: $583.71 (in dollars but euro price is about the same)any recommendations for a budget case?
Since your board is MicroATX, you can get the Coolermaster Q300L
If you want to stick to ATX cases to keep future expansion options open (in case you want to go to an ATX board later) you could get the Focus G, SPEC-04 or the Thermaltake Core G21 TG Edition. You could also look at the Coolermaster MB510L or MB511 which are around $50/€50
https://linustechtips.com/topic/1043645-case-help/#findComment-12388309
Corsair SPEC-04 works well for a budget case, and is relatively easy to build in.  There are two versions to choose from if you want tempered glass or an acrylic side panel.  A nice perk to the TG version is that it's a full view of the side, while the acrylic has a window on a metal panel.  Let me know if you have any questions about the case.
Looking for more details about a product, or experiencing technical issues?  Visit our support page below, and one of our Technical Support staff can help you out:
https://support.corsair.com/
https://linustechtips.com/topic/1043645-case-help/#findComment-12389330
