Corsair H80i fans
Solved by zinton,
I think the magnetic bearings on those fans are just about the best you can get.
As far as pressure goes the description says this
- Custom Rotor Design: delivers the perfect balance between high static pressure and high airflow, operating flawlessly in the most challenging environments
Here are the tech specs for the fan
Static Pressure 0.2 - 4.2 mmH20
And here are the tech specs for the NFF12, considered somewhat of a golden standard.
Static pressure 2,61 mm H₂O
So it appears the corsair can push the air harder and the nff12 can push more air. There is also noise, and bearing lifetime to take into consideration.
Sources:
https://www.corsair.com/us/en/Categories/Products/Fans/Magnetic-Levitation-Fans/ml-pro-config/p/CO-9050040-WW#tab-tech-specs
https://noctua.at/en/nf-f12-pwm/specification
Sources:
