Rx 580 or 1660ti for 1080p 60fps
Solved by SupaKomputa,
29 minutes ago, XenonRxd said:So i have i5 6500 and i am thinking of upgrading my 1050ti to rx 580 or 1660ti..i just want solid 60fps at 1080p high or ultra settings..so which card should i buy? Used rx 580 is about 100 dollars cheaper here..also it should be future proof
580 should be solid 60fps on high / ultra.
AMD will soon release navi, i say you buy 580 now and swap to navi if its better than 1660.
For future proof, i think 1660 is better than 580.
Get a 580 and for the $100 upgrade your CPU to a i7.
