please make your posts in coherent english, dont just press random on a dictionary page
Builds:
https://linustechtips.com/topic/1036591-slow-wifi/#findComment-12325328
12 minutes ago, Crijix said:
Translate: Gaming on WiFi with PC ( I assume) is slow, but playing on Xbox is fine.
Your Xbox is probably closer to your router and that's why you have better speed.
It might also be using 5Ghz wifi instead of 2.4Ghz (because distance? because wifi card in PC?).
Solution: buy an ethernet cable.
https://linustechtips.com/topic/1036591-slow-wifi/#findComment-12325350
46 minutes ago, Mayushii said:
is this Google translate bingo
Google Translate gives better results.
If the question really is about slow connection speed, what are you using to test it? Because download source has also meaning.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1036591-slow-wifi/#findComment-12325412
