How to limit data usage per device on router?
Cuboid88
Hello, I'm currently using a Huawei b310 given by my provider for internet, however, I have a few other people on the same connection and I want to limit the amount that each of them can use. I'm open to using external software but no other hardware.
-Thanks very much!
Just now, Electronics Wizardy said:
How do you want to limit them? Just cut them off after so much usage? Limit their max speed?
no just cut them off after they've used all of the data
That depends, does your router even have such a feature?
Different brands do it differently. I know with Netgear you can prioritize certain devices to have more bandwidth shared to them.
Mobo: Z97 MSI Gaming 7 / CPU: i5-4690k@4.5GHz 1.23v / GPU: EVGA GTX 1070 / RAM: 8GB DDR3 1600MHz@CL9 1.5v / PSU: Corsair CX500M / Case: NZXT 410 / Monitor: 1080p IPS Acer R240HY bidx
I don't know that why I'm asking
Yea most consumer routers won't do this for you. Something like pfsense or other advanced routers can do this.
I'm not remembering it off the top of my head, but isn't there a program that Tech Youtubers have advertised that can do this (I think Linus has done an ad for it, but I can't remember)?
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
Glasswire maybe?
3 minutes ago, Cuboid88 said:
Glasswire maybe?
It was glasswire, but I think that was paid (maybe it had a trial?).
8086k
aorus pro z390
evga 3070 ultra
but then thats client based, they can just uninstaqll it.
Dang. So hardware is the solution.
8086k
aorus pro z390
evga 3070 ultra
tomorrow I'll try with the pfsense stuff and ill keep looking for other alternatives as well
Replace your router with something capable of running Tomato WRT, DD-WRT, or anotehr WRT variant. If your Huawei device is the modem & router together, you'll want to bridge mode it, then add your own router that can run the aforementioned firmware. Alternatively, simply contact your ISP or Huawei and demand they implement real features in their hardware, or give you a replacement device that supports such features, otherwise you're switching providers. Then try to switch providers and realize that none of them offer hardware with such features, so it's back to getting your own router anyway.... :( I hate consumer electronics.
Desktop: KiRaShi-Intel-2022 (i5-12600K, RTX2060) Mobile: OnePlus 5T | Koodo - 75GB Data + Data Rollover for $45/month
Laptop: Dell XPS 15 9560 (the real 15" MacBook Pro that Apple didn't make) Tablet: iPad Mini 5 | Lenovo IdeaPad Duet 10.1
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 | Panasonic TS20D Music: Spotify Premium (CIRCA '08)
