Building my 1st PC
Go to solution Solved by Cereal5,
5 minutes ago, Kurinto said:
Out of Curisity what is wrong with the selected PSU? It appeard to come highly recommended.
Low quality. This can be anything from poor over-draw/over-power protection, voltage ripple, even bad soldering. I can't speak to that PSU's draw backs specifically, but just because it has good reviews does not make it a good unit. One of the ones I recommended has all of the above and are generally considered to be some of the higher quality units on the market. Being fully-modular is just a bonus.
Also, since the PSU is connected to literally everything in your computer, if one fails it can cause damage to anything (and everything), and PSU manufacturers are not responsible for anything other than the PSU, should that happen. I try to make sure people understand that a power supply is easily the most important purchase in your entire system. If you want to read into other PSUs more, you can take a look here.
Hi All,
I am working on building my first Gaming PC. I found a few parts and was looking for suggestions. I would like to keep it in the $1000-$1500 range.
Uses:
1. Gaming
2. Streaming
Currently I am only concerned with the PC Tower itself. I don't need any extra Peripherals.
Suggestions I am looking for:
1. Is there a better part then the one I picked out in a similar price range?
2. Will any of the parts I picked be an issue?
Link:
Welcome to the forum!
What country are you located in? What resolution/refresh rate will you be playing at? And any idea for what games?
edit: Any reason why you chose SLI 970s? Do you already own them? Or is that what you are thinking about buying? (read my signature lol)
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
US, 144 Hz, DBZ Fighters, Witcher 3, Fallout 4, or similar games.
I actually noticed there was an error. I was only going to get 1 GPU. I must have added it twice.
Please quote or tag people when responding so you get a response faster @Kurinto
Here's what I came up with for you:
You have plenty of extra budget to throw in more goodies and such if you want, like your OS and case fans. The 2700 will definitely out perform the 8700K in streaming. Maybe not so much in straight gaming, but you get a great CPU for much cheaper. You can upgrade to the R7 2700X if you don't want to do any overclocking, and you can use the stock cooler for either CPU if you want to save another $60. A GTX 970 is great for 1080p60Hz gaming, but it will start to struggle if you want 120+ fps in games like FO4 and Witcher 3, or any AAA title. An RTX 2060 will be a huge leap up and should last you quite some time, and will play 1080p144hz very well. Feel free to ask any questions.
9 minutes ago, Cereal5 said:
@Cereal5
If I wanted to go with the Intel still what would you recommend for a motherboard? I think I will probably be doing more gaming then streaming.
Thanks for the recommendation on the GPU as well I will definitely add that to the upgrade list regardless.
@Cereal5
I would go with something like a Gigabyte Z390 Aorus Elite. The Z390 Aorus series motherboards are very good for overclocking and are fairly affordable. Also, I would stay far away from the PSU you put in your original build. I would recommend an EVGA G2/G3 unit or a Corsair RMx/RMi unit. They are all fully modular and are very high quality PSUs. I would still definitely consider the AMD platform, as like I said you get a lot more CPU for your money, and it's more than enough for triple digit fps numbers. The only time I wouldn't recommend AMD is for something like esports gaming with a 240hz monitor.
