Which monitor? 23 or 21.5 inch?
nkucz
I currently have a 20" crappy monitor and I'm looking to upgrade to one of these, but I'm not sure if 23" will be to big. Which do you guys think is better?
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236310
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236363
Intel i5 3570K || Gigabyte GeForce GTX 1070 8GB FE || 8GB Crucial Ballistix Sport 1600MHz || ASRock Z77 Pro 3 || WD Caviar Blue 1TB || Noctua NH-U12S || Creative Sound Blaster Audigy FX Sound Card || Fractal Define R4 || Gigabyte GC-WB867D-I REV 4.2 Wireless Network Card
ASUS VC239H Monitor || Corsair Strafe Cherry MX Red || Logitech G Pro || Philips SHP9500 w/ V-MODA BoomPro Mic || Reflex Lab Pro 36 Heavy Mouse Pad || Google Nexus 6P 128GB
21.5" Is so much cheaper, I would defenitely take the 21.5" one.
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
I'd say the 23 inch but if you feel that your screen right now is too small. If it just enough then get the 21.5 inch. Also look at other IPS monitors. Get this AOC, it something in the middle of the two sizes. http://pcpartpicker.com/part/aoc-monitor-i2267fw
Quote me to get a reply!
I am a big fan of my 23'' monitor. it's all about personal opinion. as long as they have the same resolutions, type of screen and generally of the same quality. bigger monitors of the same resolution will distort the image slightly. most of the time you wont be able to tell the difference though.
CPU: AMD FX 6300 @4.2GHZ | MSI 970A-G 46| Gskill Sniper 2X4GB 2400| Samsung 840 EVO 120GB| NZXT Phantom 410 gunmetal|
Apevia 680W Iceberg| HIS R9-270X| WD green 3TB|
23" won't too big. But I would get the 21.5" if you like the size of your current monitor, mainly because it is like $75 cheaper
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
since they both use the same resolution, 1980 x 1080, I would go the 21.5" you would have slightly higher pixel density.
Use the quote or multiquote, for faster responses \/ \/
Go bigger. Always bigger.
Really though I had a 20" and went to 24", and I'll never go back.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
The thing is my 20" seems kind of small but my desk isn't that big and I'm going to college next year and won't have that much room, I'm really stuck haha I like the price of the 21.5" though
I realllly doubt you'll ever notice the extra 7 pixels in that 1" space.
If you don't think you will have space for a 23", get the 21.5". Also, if you get the 21.5" you can upgrade peripherals, headphones, etc.
Will I notice any difference going from 20 to 21.5"?
24" is my personal favorite size. 21.5" is really small and I think you should at least get the 23", the difference in space it will take up is small, but the difference you feel when looking at the screen is huge. The 21.5" is proper cheap though, holy balls. It really only depends on whether or not you're short on cash.
dat sexyness...
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
my graphics card only has display port and mini hdmi though, and converters suck balls
It is always the same. Me and my sister were using a 15,6" laptop. Then she got a new computer with a 22" monitor and it seemed huge. Now I have a 23" and you can see the difference. I hate using her PC, fullHD or more, 23"+ for life.
PC: CPU: Intel i7-4790 MB: Gigabyte B85N RAM: Adata 4GB + Kingston 8GB SSD: Samsung 850 EVO 500GB GPU: XFX GTR RX 480 8GB Case: Advantech IPC-510 PSU: Corsair RM1000i KB: Idobao x YMDK ID75 with Outemu Silent Grey Mouse: Logitech G305 Mousepad: LTT Deskpad Headphones: AKG K240 Sextett
Phone: Sony Xperia 5 II
ik, but the card you link only has DVI and VGA I was saying :) it is sexy though
It's slight but noticeable.
21.5" and 23" is preference though. I prefer 23" and my friend prefers 21.5".
If you're open to other options:
http://www.amazon.com/dp/B009V8F700/?tag=pcpapi-20
http://www.amazon.com/dp/B00CLZ047Q/?tag=pcpapi-20
2.15" and 23" is preference though. I prefer 23" and my friend prefers 21.5".
*draw-drops* holy shit those are beautiful!! are they higher quality than the Asus ones I linked?
Shrug*
I'm not sure about that.
The Asus display has a better and more stable stand.
Shrug*
Yea the complaints on the AOC one, said that the monitor came crooked a lot of times.
It's really personal preference. Although the IPS 23" would probably look better, even though it might be just marginally.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
I'd say once you go bigger you'll never wanna go back. Perhaps that sounds wrong. To me, the size of the screen can only make a difference depending on how far back you will be sitting away from it.  I have done enough asking around to settle on this model for myself after comparing with a similar AOC. It will be obnoxiously big on my cheap Staples desk but I don't care.
Stick with the 21.5" or compare the model I mentioned.
NZXT H440 l Inel Core i5-4670K l Z87-GD65 l MSI 780 Twin Frozr l Kraken x60 l Corsair RM 650 l Seagate Barracuda 2 Tb l Corsair Force GS 128 Gb l Teleios Sleeving l Acer H236HLbid l Corsair K70 Anodized Black l Roccat Kone Pure Color
