Will static actually hurt my parts?
Vod
Hello!
So I'm going to build a new pc very soon, and when I ussualy look at pc building guides I ussualy see them telling you to take and anti static wrist band or and some kind of a base where you build your pc.
I don't have any of those items, so will it somehow hurt my parts or me if I don't use an anti static thing?
I zapped a graphics card once and had a heart attack that I ruined it. I got lucky and didn't, but static can damage components that are more sensitive. An easy way to reduce static build up is to work away from carpet, and you can also touch a large metal object like a shelf or a sink every couple minutes to release buildup.
Primary PC:
Nah, you can if you really want to but you'll be alright. If you wanna be careful about ESD, plug in your PSU while you work and touch it occasionally (to ground yourself) or just touch something metal (that isn't a pc part)
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
I personally don't use those items, but use some common sense, do not build in your socks standing on carpet while rubbing your feet around. Ground yourself out as often as you can(touching conductive materials, most metals).
Static WILL fry parts if it jumps to them. But in my experience is not extremely common as long as you don't doing dumb things.
Ryzen 9 3950x - 64 GB DDR4 - NVME 980 pro SSD - EVGA RTX 3080 FTW Ultra - FAD CASE
Full custom loop / links below out of date
LTT Build Log | PCPP Build Log
_____________________________________________________________________________________________
Sorry if I stop responding, I've probably gotten busy as I mostly am only on here while working.
Short answer YES they can harm your parts.
You don`t need an anti static thing attached to your body just touch some large grounded object like your room heater.
You don't need to take all of those precautions. Just touch something metal that's grounded (plugging in a PSU with a ground pin and touching the metal chassis will do this) and any static build up you have will dissipate.
If you are paranoid about static, then sure.
3 minutes ago, Vod said:
Hello!
You don't NEED an anti-static wristband, you just need to be careful.
Yes, static electricity can kill parts, but the chances of that happening are incredibly slim.
If you're concerned, unbox your power supply and plug it in, then regularly touch the outside of the PSU casing (NOT THE CONNECTORS) to discharge static electricity.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
Great minds think alike. ?
Stille (Desktop)
Evoo Gaming 15"
Love that: "Ok just to be sure he does not fry himself"
Here is a video from Jay on the topic.
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
Some people understand electricity better then others. I don't want to assume and give someone generic information that they can misinterpret. :)
Stille (Desktop)
Evoo Gaming 15"
5 minutes ago, RollinLower said:
for everyone commenting that static will kill your pc, watch this video please.
I see you meme video, and I raise you a 30Kv tesla coil!
Stille (Desktop)
Evoo Gaming 15"
And abusing pc Components by throwing them gentle and rubbing them at each other, tells you what about anti static will not kill your components?
I bet i can kill parts from just ESD from my body. You can charge yourself enough to do damage to sensitive components.
CPU socket is only part which you can cause some damage, but even that is unlikely. Don't build on carpet and ground yourself before installing CPU. But overall static is least problematic part of building process.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
I build my own in various different conditions, including in socks on carpet. One of the things that I made sure to do on my first several builds is to have the power supply unboxed and plugged in, but not turned on. The PSU is now a grounding point. Before I went and touched any part, I'd touch the PSU first to discharge any static that may have built up.
Now, I know what I do that can generate a spark-able charge and generally don't do those things any more. Haven't had a discharge when building for a long time. (Static, that is.)
Or you could do like the Verge and put a rubber band around your wrist and say you are safe. </sarc>
Well if you do then you have 1 upped Jay, and Tech YES City.
31 minutes ago, Vod said:
Hello!
My testimony - I build computers on carpets wearing wool socks while shuffling around like M.J. doing the Moonwalk.  In my 20 years + of doing this Ive never had issues with static.  I still ground myself before touching parts though out of habit.  They also say you shouldn't use a vacuum - because it creates static.  I use a vacuum to clean my PC's all the time.  Again, just ground myself prior.
Should you use an Anti Static Mat and Wrist cable?
Yes.  Especially if you feel like you should.  Me?  Im cheap AF and tbh would RMA something that didn't boot up correctly anyhow.  But again, never fried a thing before.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
where do you get this experience tough? yes, what you say holds some truth, tough these days literally every board is secured for things like this. i repair PCB's for a living (granted, they're PCB's from welding machines, tough the same priciples apply here. a PCB with a microcontroller or CPU and the surrounding components) and even the cheapest board from the cheapest china-made welder has some diodes to protect the sensitive components.
the chance of the static your body releases actually getting to the sensitive components is minimal at best.
100%
I mean I literally moonwalk in wool socks on carpet while building PCs for 20+ years.  Until you can SHOW me this will hurt components, I consider it an old wives tale that carries SOME weight, and that I should ground myself at minimum, and that's enough.  Has been for me, for a LONG time.
Yes but a blown diode is still a blown diode, which means the entire part is broken as far as the end user is concerned.
true, tough i have yet to meet the person who can build up enough static to blow a diode.
i'm sure it is possible somehow, somewhere. tough 99% of the time it won't happen. especially if you just touch a grounded object before touching a part.
Actually now that I think about it since I've been brushing up on the subject, I'm curious how much current is in a typical static discharge and if that's enough to break down a part.
All voltage does is it makes an insulator a conductor if high enough.
Scroll down to "energies involved"
https://en.wikipedia.org/wiki/Static_electricity
Stack overflow as well:
https://physics.stackexchange.com/questions/177961/what-is-the-voltage-of-an-average-carpet-static-shock-can-you-make-it-lethal
TL;DR, largest shock recorded by a human was 35KV at 100 mJoules from a car seat.
That stack overflow thread is a fun read.
Stille (Desktop)
Evoo Gaming 15"
