I've decided I want better performance with my PC, the current build is a Ryzen 5 1600 with XFX RX 580 and a Seasonic M12II-520 520W. I tried overclocking my cpu, I once got 3.8Ghz stable but then I tried OCin my GPU just a TINY bit, it crashed and now I put everything on base clock just to be safe.
Would I get better OC with a bigger watt PSU? I'm currently looking at Seasonic S12II-620 620W or if there's something better please recommend me. Thank you.
https://linustechtips.com/topic/1015946-does-psu-watts-effects-overclocking/
I run an overclocked Ryzen 5 1600 and an overclocked GTX 780 on a 550W unit, you shouldn't have any issues with that setup.
Did you increase the power limit for your GPU?
I don't think so, all I did was edit the frequency on Radeon settings WattMan
no, that PSU provides PLENTY of power, don't know what you're doing but maybe you're inexperienced with overclocking
how much is a tiny bit for the GPU? and you should increase power limit on it when you overclock, and as for the CPU, i have no clue what voltages you're running at and maybe 3.8 is the limit of the chip, its low but possible
Quote or Tag people so they know that you've replied.
I'm a beginner with overclocking. I think I went 1.4V on the CPU when I got 3.8Ghz. I tried 1430Mhz which is 5Mhz above the OC+ clock based on XFX's website, max I got is using the OC+ settings XFX gave.  I will try increasing the power limit on the GPU, thanks.
"Bigger watt" is not the same as "better". And there are so many more things to a power supply than watts.
Will watts affect your overclocking? Probably not. Because your 520W PSU (really just 480W since that's all on the 12V rail) is more than enough for your system needs.
But what would affect your overclocking is the power supply's voltage stability. And your particular power supply isn't very good at that.
The M12ii PSUs are rather low quality.
The crashes may be caused by unstable voltages delivered by your power supply. You can use a multimeter to test.
But not by a wattage shortage.
Otherwise the problem lays elsewhere.
Alright. Thanks alot
Not really as long as you still have sufficient wattage but PSU quality does matter as the electricity going to your components can be either right or wrong which will mess up system stability and a M12II-520W is by today's standards is a very shitty PSU.
Personal Desktop":
Luna, the temporary Desktop:
Why just why?!
Why do people still consider a 2010 PSU for modern components?
Can you still return it?
Here Info:
You get the same shit with higher wattage.
The Wattage isn't the Problem, the quality of the PSU is, regardless of the OC values.
The 520W was a mistake.
But then again, its entirely possible that the CPU doesn't go higher.
"Hell is full of good meanings, but Heaven is full of good works"
Wattage?  Not so much.  OC can easily double your power consumption at times, but you're still within reason wattage wise.
QUALITY of power plays a bigger part.
On 1/2/2019 at 9:54 PM, Stefan Payne said:
Why just why?!
Here Info:
Would something from tier 2-3 from the PSU tier list be good enough for what I'm trying to achieve? The only thing I can afford in the tier 1 is the  Bitfenix Whisper M 550W
 Also no, I can't return it because I made this build in mid 2017 rip
That's a pretty good PSU, so why not go with that??
The Rest depends about what you are really talking about...
In general no..at this point..a more stable unit on the rails might help some though....
It's just overall handling and wattage...you can hook up more shit to it and a load.
2600x 4.3ghz-Loop
Msi X470 gaming plus
EVGA SuperSC CL16 3200 16gb
gtx 1060
pny nvme 480gb
mushkin eco3 480gb
Sound Blaster Audigy FX
Cooler Master GXII Pro 750w.
