Meshify C case fan question?
Hello all, I have a question regarding best fan placement for Meshify C case. My son and I are building a gaming rig and have 6 Corsair LL120's for cooling. The CPU and GPU are Ryzen 2700x with wraith prism cooler and Asus Strix 1080ti. Power plant is EVGA Supernove 850 G3. What would be the best fan placement for the case? My thought was 3 120's in front for intake, one in back exhaust and 2 up top exhaust. I still have the factory fans that come with the case. Thanks in advance for the suggestions!
https://linustechtips.com/topic/1009105-meshify-c-case-fan-question/
if you don't care about dust then your plan is good. Otherwise put the top as intake and use the air filters.
Desktop benching:
So actually theres a topic about this in this same forum. This guy recommends 2 quiet 140mm fans at the front for intake without exhaust
PS: please upgrade that HDD
i7-9700k | AsRock Z390 Phantom Gaming ITX | Corsair Vengeance LPX 2x8GB | EVGA RTX 2080 XC Gaming | Samsung 860 EVO | Corsair SF750 | Ncase M1
Thanks for the link, I'll check it out. What would you recommend for the HDD and why?
why HDD if we have affordable SSD with obvious performance gains?
I think your config will be fine. You can control the-always-feared dust by having exhaust spinning slower than intakes. Since you are using stock cooler, you could spin top fans almost zero speeds, just having lighting effects going on. Rear will be enough for doing exhaust work by its own.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
That seems quite strange since hot air rises.
PC: Case: Cooler Master CM690 II - PSU: Cooler Master G650M - RAM: Transcend 4x 8Gb DDR3 1333Mhz - MoBo: Gigabyte Z87x-D3H - CPU: i5 4670K @ 4.5Ghz - GPU: MSI GTX1060 ARMOR OC - Hard disks: 4x 500Gb Seagate enterprise in RAID 0 - SSD: Crucial M4 128Gb
Phone: Samsung Galaxy S6
Removing the NF-F12 at the rear didn't make much difference since it doesn't provide that much airflow especially for the noise. It's not a great fan for an exhaust mesh that isn't very obstructive.
The effect of air rising is negligible when there's active airflow.
If that hot air can overpower the fans, then we should use R9 290X graphics cards to power hot air balloons.
Desktop benching:
Or at least get the middle solution by getting SSHD which offers around 5x faster than conventional HDD but still has the higher capacity than SSD with reasonable price in between HDD and SSD price range.
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
I recently built in this case and went with four SILENT WINGS 3 fans in the case.  Three up front for intake and one in the rear for exhaust.  It's been working great and the fans are silent.
Keep the FD fans but don't put them in the case.  The LL fans you bought will be great.
"And I'll be damned if I let myself trip from a lesser man's ledge"
Thanks! Yeah, I'm definitely gonna keep them for emergancy or another build.
The LL's work great in these for cooling, i seem to get a lotta LL's sent to me from corsair so i just go with those,
I'm Running the same as narrdarr's  cept 140's up top and push pull on the rad just for the hell of using the extra fans.
It's not the dust collector i thought it would be, i think running the top fans with the mesh filter helps a bit.
These are really short cases running WC or AIO's @ the front can limit your GPU choice to under 290mm
Do you want optimal for temps, do you want quiet?  Do you like cleaning your PC?
Optimal is as much cool air in as quickly as possible, while exiting the heated up air as quickly as possible.  Your current setup, for that case on air coolers - is optimal.  Unless there are more places to mount fans (I don't think so on that case).
I would never use top as intake - that's fighting the laws of thermal dynamics.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
"affordable"
$200+ vs $50 for 1TB
3- years random RW lifespan (maybe even less for samsungs) vs 10+ years
Keep the HDD OP it's just odd how some people talks about SSDs as if they were some kind of alien tech or something, I load games from my HDDs perfectly, the only noticeable performance gain is in the boot time and the difference isn't even that big vs a hard drive... but anyway, whatever floats your boat I guess
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
Boot time is just a cool thing to show off or compare. The biggest difference with an ssd over the hdd is a more responsive and snappy system.
5 hours ago, aezakmi said:
"affordable"
WD 1TB SSD are only 150$ 1TB SSHD about 60-70$ and 1TB HDD about 40-60$
Load times are much different when comparing SSD to HDD.
