It's completely fine if you mounted it properly.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12076836
On 12/13/2018 at 10:23 AM, Gorge said:
 Hey I was just wondering is my CPU cooler too heavy for my motherboard? It is in MSI core frozer L  with a thermaltake riing led fan on it in red  is it too heavy for my motherboard?
It is at 960 grams not including the fan
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12076840
It's fiiine.
The NH-D15 or the PH-TC14PE are much bigger and they are also fine to mount.
Only thing i would do if you are planning to transport it, it might be a good idea to take the cooler out (and the gpu if you have one) because those are the most likely to break something during transport.
And i don't mean just from room A to B but actually putting it in a car or something and driving for a while.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12076847
19 hours ago, samcool55 said:
It's fiiine.
so it can take some vibration from subwoofer?
19 hours ago, aisle9 said:
If you mounted it properly with the included hardware, not even a little bit. Google "NH-D15"
cn it take vibratin from subwoofer?
ok can it take vibration from subwoofer? and vibration on desk?
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12076980
Yeah that's fine. The amount of force we are talking about that could cause something to break is dropping the system from your desk or putting it in a car and driving over a pothole.
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12077000
 So Not anything like for example somebody jumping around in my room? Stupid example I know or even  like the house vibrating?
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12077454
No, not even if you throw the PC on your bed.  Keep asking tho, these examples are making me giggle :)
Throw the rave of the century, you'll be fine.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12077502
You mean like an earthquake? Yes, anything above a 6.0 (or a sustained 5.0) within 25 miles of the surface below your house and you're probably screwed, but the cooler will be the least of your worries. Short of that, here are a list of things that will break the cooler off of the motherboard:
  • An elephant stomping on the case.
  • Dropping the case off a three-story building.
  • Tossing a flashbang grenade inside the case and putting the side panel on.
  • Shooting it.
  • Kicking it.
  • Humping it.
  • Putting it on its face (cooler hanging down) in the back of a Jeep and going off-roading.
  • Putting the system in a shopping cart and the top of a hill and pushing it down while a car drives towards it at 60mph, resulting in a collision with an effective speed approaching terminal velocity.
  • Detonating an atomic bomb in your basement.
  • Rosie O'Donnell sitting on your PC.
Seriously though, in the grand scheme of things, that is a pretty average sized cooler. As long as you used the mounting hardware that came with the cooler, made sure to follow the instructions and avoid abusing your computer in any of the ways mentioned above (or similar activity), you're pretty well safe. Nothing in life is ever guaranteed--aside from OEMs playing tricks with their benchmark results so they can make zany claims--but you're not likely to have a problem if your cooler is mounted properly.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12077571
  • Shooting it.
  • Kicking it.
  • Humping it.
THREAD KILLER!
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12077580
  • Shooting it.
  • Kicking it.
  • Humping it.
Bullshit, humping it does NOT break the cooler.... oh nm.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12077639
 All I’m going to say is you never know...
On 12/13/2018 at 1:51 PM, Tristerin said:
THREAD KILLER!
You made my day
  • Shooting it.
  • Kicking it.
  • Humping it.
  You made my day, and yes humping broke the cooler dammit!!!!!
My PC  is above the weight room and I drop weight down really hard when I am done lifting and I think the vibration goes to the Ceiling, in which he PC is on a metal desk above this
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12078005
That's not a huge cooler, I mean its nice...but Ive seen bigger ;)  Unless its mounted incorrectly I wouldn't worry.  If you ARE worried (cause your not me) then put the case on its side so the cooler is now being forced down by gravity on the slot...no more worries
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12078131
Unless the PC is suspended face-down from the ceiling, you're good. And if your PC is suspended face down from the ceiling, I'd like to see pictures of your setup.
That's what your girlfriend said last night! OOOOOOOOOHhey wait a second
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12078269
Lol
 Yes it’s a nice CPU cooler, but not like overkill big I know, I still idle at 25°C and load at 58°C
On a i7 7700K
Just bought an MSI core froze or L and put an aftermarket fan on it, it now weighs about 1000 g is this too heavy for my motherboard?
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12078767
that's fine as long as you mounted it correctly there are bigger coolers out in the market
 like the dh-15 which weighs about double as much as yours
ps. didnt i see this thread before O.o
edit: nvm i may just be a dumb
Edited by Happycowdance
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12079119
Please don't make duplicate threads.
Anyway, you'll be fine, 1000 grams is actually way beyond the weight needed to break an average Mobo.
Also, as long as you tighten it up correctly, vibrations won't make it come loose.
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12079194
Still no. The mounting hardware is designed to distribute weight of cooler across whole mobo. That being as long as both are properly and tightly mounted. Vibration or shaking the case won't have any effect. Only hard shocks like dropping the case from 1.5-2m. But that will also break PCIe slot, which is much more fragile.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12079885
...seriously, you're good.
https://linustechtips.com/topic/1007835-big-cpu-cooler/#findComment-12080074
