Can the cable cover move over a bit on the h500? I have an eatx mobo and im afraid the 24pin wouldn't fit nice without taking the cover completely off. if I wasn't clear I ment the red thing. because from the back and side angles it looks like theres screw holes that kinda tell me it can be moved a bit.
https://linustechtips.com/topic/1006329-h500-cable-cover/
No.
https://linustechtips.com/topic/1006329-h500-cable-cover/#findComment-12062296
It's bolted in a fixed position, also check closely with your motherboard as E-ATX can have both wider and taller boards, it tends to vary.
https://linustechtips.com/topic/1006329-h500-cable-cover/#findComment-12062304
7 minutes ago, AgentAY said:
just a bit wider. 272mm.
Hmm looks like the H500 does have two sets of mounts, it's hard to say exactly without a better photo of the side to see if there is anything that interferes. They don't document that as a feature from what I see in their quick start guide.
https://sta3-nzxtcorporation.netdna-ssl.com/uploads/download/attachment/727/H500i_H500-manual-ver4-071618_-_web.pdf
https://linustechtips.com/topic/1006329-h500-cable-cover/#findComment-12062341
that's what I noticed too. im going to email nzxt customer support or something and ask them. because I watched a ton of youtube videos on the case but none of the people mentioned that the bar moves.
https://linustechtips.com/topic/1006329-h500-cable-cover/#findComment-12062455
Someone asked this question (but i cant find it) but after some research I do believe that cable cover is adjustable, but it means you wont be able to put a front mounted rad at the front.
Confirmed at least for the H700, 400 and 200 series
https://linustechtips.com/topic/1006329-h500-cable-cover/#findComment-12065622
I believe its the same for the h500. since theyre damn near the same case. thank you so much! my only question now is, would I be able to put a 240mm rad (corsair h100i v2) in it with the bar moved over?
https://linustechtips.com/topic/1006329-h500-cable-cover/#findComment-12069123
For reference, this is your spacing with the bar in the stock position. The bump of the bar would prevent a 240mm rad from fitting.
Image result for h500
https://linustechtips.com/topic/1006329-h500-cable-cover/#findComment-12069136
