3200mhz ram clocked at 1600mhz?
Go to solution Solved by Jimkirk363,
Its Dual Rate so its 1600 x 2.
Hey doots,
I have two sticks of DDR4 3200mhz CL16 ram, but when I run UserBenchmark it gives me this:
Why does it say clocked @ 1600mhz? I put the ram sticks in slot A1 and A2.
MAIN PC (Beast) - Asus ROG Crosshair Hero VII WIFI  with BIOS 4703, AMD Ryzen R9 3900XT + Corsair H115i Pro RGB XT Cooling, 32GB G.Skill 3200Mhz 16,18,18,38 1.35v DDR4, Inno3d HerculeZ Design Nvidia GTX 1080 X2 8GB GDDR5,  1 x Samsung U28E590D & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 3TB Seagate Barracuda SATA III, 1 x LG BH16NS40 16x BR\DVDRW, ICYBOX IB3740-C31 & ICYBOX IB3640-03,  MZHOU 7 Ports PCIe USB 3.0 Card, 1 x XIAOLO 2.5G Intel I225V Ethernet Card, 2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Corsair Obsidian 750D Wind Force Edition Case + 5 Corsair ML140 140mm Case Fans, EVGA 750 g3 750w Gold 80+ PSU, Logitech MX Vertical Mouse, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, Synology ds215j NAS + 1x3TB WD Reds connected to a 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
so nothing wrong right?
Nope, it's normal for any kind of DDR RAM.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
Cool, thanks dudes
Because it isn't 3200MHz, it's 3200MT/s. Thank this BS on some salesman trying to make RAM look faster than it is.
AWOL
So my ram is slow?
No, that salesman BS he's referring to is industry wide.
(Copied from Wikipedia)
The name "double data rate" refers to the fact that a DDR SDRAM with a certain clock frequency achieves nearly twice the bandwidth of a SDR SDRAM running at the same clock frequency, due to this double pumping.
So the clock speed will be shown as 1600 MHz, but the bandwidth is doubled so it's marketed as 3200 MHz.
https://en.wikipedia.org/wiki/DDR_SDRAM
Ok cool :D
13 hours ago, WhatComesAround said:
So my ram is slow?
Your DRAM uses a 1600MHz clock. DDR double data rate means it can transfer data on both rising and falling edges of the clock meaning it can transfer 2 bits of data per clock. IOW 3200 Mega Transfers per second or 3200MT/s.
Understand it for what it is. If all manufacturers stuck to advertising the real clocks then this confusion would not come about and you would not be here asking your question.
FYI the current world record for DDR4 (which is liquid nitrogen cooled) is 2783MHz so don't go thinking your RAM is running at 3200MHz. Once one manufacturer advertises twice the clock frequency (as effective frequency compared to non DDR from a long time ago) then the others have to follow or lose sales because the average person will assume the double frequency is better.
Similar has happened with disk drives, instead of the binary kilobyte (1024) they use the metric kilo (1000) so a 186GiB drive shows up as a 200GB drive. So far RAM sizes are safe as a 16GB DIMM is actually a little over 17GB using the metric measurement.
Another way to look at it is when say a 4GHz CPU operates in 32-bit mode it uses 32-bit general purpose registers but in 64-bit mode it uses 64-bit general purpose registers which are double the width and can transfer twice the data per clock but it doesn't mean it's operating at 8GHz.
TLDR No, it's not slow.
AWOL
Ahh I see, but doesn't that fall under false advertising? I mean how can they just mix around figures with different specifications?
I wish :)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
That would be a question for a Lawyer. Do you feel you have been cheated because you expected 3200MHz - 64000MT/s or concerned that your RAM was running slow? Does your RAM physically show DDR4-3200MHz or DDR4-3200 with the MHz not shown? Is there some fine-print that explains it as "effective frequency"? What would you get out of it, just a refund or a change in advertisement?
If you look at DRAM spec's from Micron you'll see they use MT/s, for example. Also same for Intel CPU datasheets, example
FWIW note the spec in the Intel example is up to 2666MT/s (1333MHz clock) which means a 1600MHz clock would be out of spec i.e. overclocked which is also quite normal.
Perhaps Userbenchmark could also be a little more helpful in it's description too.
AWOL
  • 7 months later...
I can't believe on THIS site, there are so many remarkable ignorant comments about DDR4.  If you buy 3200MHZ RAM, your OS is SUPPOSED to see 3200MHZ in the task manager and CPU-Z.  If I could physically slap each of the commenters I would.  I almost refuse to believe ALL the people on this site have purchased DDR4 and are happy with the using the SPD timings.  SHAME on ALL of you for misleading ALL the google searches and readers of this forum.
I have had my Corsair Dominator Platinum 3200MHZ CL16 working on my X399 SLI+ at 3200MHZ MANY MANY times with older Windows 10 builds.  I recently (like an idiot redid my WIndows 10 install media) and reformatted my computer when I couldn't get my FLAREX 3200MHZ CL14 past 1600MHZ.  NOW, i'm stuck at 1600MHZ on the Corsair & GSkill.   I found this thread in my troubleshooting.
PLEASE, PLEASE, PLEASE for the love of God do not insult my intelligence and ask if I have the XMP profiles enabled.  YES, I HAVE XMP enabled.  I have tried both profiles.  XMP profile 1 will downclock the DDR4 to 1473MHZ.
99%of threads are people 'reminding' people to try XMP or saying "NO its OK for your DD4 to be running SPD.  You're doing great..."
LETS get some constructive analysis of these inquiries.  NO XMP doesn't work.  YES your 3200MHZ RAM is supposed to show up as 3200MHZ in the BIOS and WINDOWS 10.
@josephredmonas we all said above, the O/S will see it as half the speed as DDR is DUAL RATE so for 3200mhz Ram u sill see 1600Mhz.
Internet Speed.....
