How hot is too hot?
Oliver davies
Hey, I'm using a cooler master hyper 212x to cool a xeon x5650. under full synthetic load I hit max temps of about 95*C after about half an hour. should i upgrade my cooler. and if I should what too. (budget is about less than £40)
Take the cooler off and check your previous thermal paste application. Does it cover most of the IHS?
Desktop benching:
yeah it does last time I reapplied. I know the interface is good but I need to know if the temps are too high.
Well, anything above 80 isn't going to be good for that cpu. Maybe a artic freezer 33 esports one will help you out?
seems to be a good idea ill have proper look at reviews
Well, there is a model of it that can keep treadripper cool, so yeah...
They have large IHS's tho and large die areas so that may help. does anyone know if you can delid x58 chips?
I tend to say that 75 is the max I'd be happy with for sustained long term use. Although that's a bit conservative. On all my folding rigs I set the max temp to 73 and I'm happy. Then again, I have good coolers for all of them so they can pretty much run full out and never reach that.
Oh ok ill see if i can drop some of the overclock in that case
they are high, but it could be just not enough mounting pressure. I got 75C on the NH-D15 on my 2600k at stock at the first time, but 60C the second time when I literally torqued it down.
Desktop benching:
You can delid X58 chips just as you can any other Intel CPU (mostly), it will yeild great results and may even result in not needing to upgrade your cooler.
i7-7700k | GTX 1080 Ti | 32GB 3100MHz | Prime Z270-AR
Delidding a soldered CPU like this isn't that great of an idea, though.
Many thanks!
So is this at stock settings or overclocked? For stock this is very high to a degree where I also suspect poor contact. You did peel off the plastic protector film on the cooler, right? :P
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
Where do you get 80 from?  How much not good is going to happen?
This is synthetic load tho, he needs to check real gaming temps.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Well, it's a general rule I use. Temps around 90 are too hot imo because on the long term it can be damaging for thd cpu. That's why my general rule is <80
I get what you mean, I was curious where the 80c was coming from.  If it's a scientific CPU damaging temp or just your guideline.  Now you're saying 90c is damaging. :)
I'll do some checking as well, I am unsure about that since the CPU has a throttling feature that should kick in before damage, which is 100c or is it 105c?
OnePlus:
Other Tech:
It's 105 on the core and 73 on the dye if I remeber right. But that's a limit, not a recommended situation. It's kinda my guidelines, it's not a scientific theoratical guideline, just mine
Heat will put wear and tear on the part regardless of how hot the part is. I've heard this thrown around in electrical engineering circles but the rule of thumb is every 10C hotter reduces the expected life of the component by half. The problem is that there's no real way to determine life expectancy. You can infer it's supposed to last at least as long as the warranty period with the stock cooler, but there are 10 year old processors that have been in regular use. There is a "too hot" temperature though, as semiconductors will exhibit thermal runaway once beyond that point.
For the purposes of this topic though, you can say a CPU is definitively too hot when:
  • Typically if the core temperature exceeds the specified maximum Tjunction. Unfortunately for this processor, Intel only lists a Tcase temperature of 81.3C. Tcase is always lower than Tjunction, and the only thing I could find that suggests how the two are related is at https://malwaretips.com/threads/intel-cpu-temperatures.66242/ (they say maximum Tjunction is about 5C higher than maximum Tcase)
  • The CPU cannot maintain base clocks during a nominal workload. If the CPU is not turbo-boosting but maintaining base clocks, then it's technically fine. It's when it drops below base clocks that's a problem, because now it's thermal throttling.
Edited by M.Yurizaki
well. I wasn't that far off with 80 then... Are you a cooling nerd?
overclocked to 4.5Ghz and i cant drop it because windows gets fucked when i do (something to do with base clock issues i thing)
thanks and as it doesnt thermal throttle  so ill asumme for only short periods of time when it peaks its ok.
looks like ill consider that.. its only a cheap chip
Per what I read from this thread, the CPU controls its thermals well, by throttling.  So 100c+ is damage, not 80c.
OnePlus:
Other Tech:
yep. that's why 80 is my max. I don't say 80 is bad. I say everything above it is bad (not talking about a degree or two)
What I'm getting at is being careful stating opinions as fact... 80c and 90c do necessarily adversely damage a CPU under a stress test or gaming.  it is well within their normal operating limits.
OnePlus:
Other Tech:
