Help making .exe file
Go to solution Solved by Franck,
50 minutes ago, ThatBlockishWay said:
I might go ahead and do that, I think a batch would be suspiscous looking though. Is making an exe a pain?
No making an exe is very easy. But batch and exe could be block by anti virus from launching. In your case a shortcut link is probably the easiest solution.
On top of my head launching a file in an exe is 1 line of code in any language.
C# System.Diagnostics.Process.Start("myfile.html");
Java : Process process = new ProcessBuilder("myfile.html").start();
I think all you need for this is a simple batch file. You could also, y'know, make a shortcut to the HTML file on your desktop as that basically does the same thing ;)
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/1002098-help-making-exe-file/#findComment-12024997
8 minutes ago, ThatBlockishWay said:
Is there a way to make an exe file that paths to an html file and opens it? I know there's gotta be but I can't find anything that tells me how.. (Also Im kinda a nub at coding so please don't expect too much outta me)
I mean, you could just create a shortcut and place it wherever.
much simpler than building a whole application just to launch a web page..
https://linustechtips.com/topic/1002098-help-making-exe-file/#findComment-12025010
What are you trying to achieve?
PC: Case: Cooler Master CM690 II - PSU: Cooler Master G650M - RAM: Transcend 4x 8Gb DDR3 1333Mhz - MoBo: Gigabyte Z87x-D3H - CPU: i5 4670K @ 4.5Ghz - GPU: MSI GTX1060 ARMOR OC - Hard disks: 4x 500Gb Seagate enterprise in RAID 0 - SSD: Crucial M4 128Gb
Phone: Samsung Galaxy S6
https://linustechtips.com/topic/1002098-help-making-exe-file/#findComment-12025030
you don't need an extra .exe, simply clicking an html file will also open the file in the browser
https://linustechtips.com/topic/1002098-help-making-exe-file/#findComment-12025050
Im making a little text based adventure game using html and I need an exe or something to launch the first file, figured thatd be better than having the player try to navigate until they found 'start'
https://linustechtips.com/topic/1002098-help-making-exe-file/#findComment-12025330
Maybe...I don't want the player thinking its a suspicious file or somthing though
https://linustechtips.com/topic/1002098-help-making-exe-file/#findComment-12025334
https://linustechtips.com/topic/1002098-help-making-exe-file/#findComment-12025994
I hadn't even considered that, thanks
https://linustechtips.com/topic/1002098-help-making-exe-file/#findComment-12026001
