Best External Dac to Improve Sound Quality
TheNinjaNextDor
I know absolutely nothing about audio except the basic stuff and my Xonar DX was DOA. Instead of getting a replacement I want to get an external solution instead because I heard they are better. What would you recommend for about $50 to $80 that will sound better than my onboard sound? Thanks!
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
FX 6300 @ 4.2 Gigahurtz 1.325V ,  ASRock 970 Extreme 4 mobo  ,  Kingston Hyperx Blu 2X4GB @1600Mhz  , Asus GTX 960 DCU ii Black OC  , Hyper 212 Evo , Samsung 850 Evo 250 GB , WD 1 TB caviar Green , Xonar DG sound card , Seasonic M12ii Evo 620W PSU , Corsair 200R case ,4 random case fans.
I think everyone is going to say fiio E10 lol
It's a simple and cheap solution :lol:
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
Yes cause no one wants go get a earful by suggesting a sound card or some other shit..............you should know what I know!
Edited by kizoku_95
What headphones do you use ?..........just out of curiosity!
Does that have mic in and audio out or just audio out?
No mic support!
Oh no! What would be a good way to have mic support?
External DACs currently do not support mic input...........someone must be able to help you out with that!
Hmmm. Thanks for the help!
Edit: im just going to buy an extension cable for my mic in and plug that into my motherboard.
Astro A40. Pretty good for gaming headphones.
Don't get a different DAC if you're using A40s. They use the optical S/PDIF output. The A40's MixAmp is the DAC and chances are you'll get little benefit.
I bought the pc version which is $100 cheaper and doesnt include the mixamp.
Ah ;) Then go for it. I didn't want you wasting the MixAmp :P
What board does the op have because chances are it will make little to no difference
Desktop -  i5 4670k, GTX 770, Maximums VI Hero, 2X Kingston Hyper X 3k in raid zero.
Laptop - Lenovo X230 Intel 535 480GB, 16GB Gskill memory, Classic Keyboard Mod, Triple USB 3.0 Express Card.
Mayflower is just above my current budget, they need to design something similar for mass production at the same price range as the fiio e10.
Easier said than done ;)
You have to cut a lot of corners to bring a good product to market under $100, something we don't want to do.
