Need some help with H7 Cooler
Taswell
I'm about to order a 1600x, but I need a cooler to go with it since it doesn't come with one. I want to get the cryorig H7 except i cant find anywhere if it includs the am4 bracket in the box or not? Its been like 6 months you think they would fix that problem (I'm trying to avoid that whole apply for the bracket after to get the cooler shit)
I only have 35-40$ for a cooler and this one seems like the best value and would let me overclock a little. So feel free to suggest other coolers
https://pcpartpicker.com/list/zNK8f8 - parts list because reasons
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
they ship you the bracket if you give them proof that you bought/ ordered the 1600x
this ^^
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Why not go with the 1600, get basically the same performance, and an included cooler?
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
it ocs worse for example
everyone know the X makes it go faster =P
Not necessarily.
Not when you OC it :P
Not necessarily.
if you oc both the x should help it go faster
That's not what the X does, and no, that isn't what happens.
the real reason the X is there is because those chips are all really self conscious about clock speeds so they slapped an X on there and gave them some caffeine to make them feel a little better about themselves
It's for people who don't know how to OC ;)
1 minute ago, cj09beira said:
acording to hwbot.com statistics the 1600x has a good lead agaisnt the 1600 in frequencies
http://hwbot.org/hardware/processor/ryzen_5_1600x/
http://hwbot.org/hardware/processor/ryzen_5_1600/
Way to quote two chips running at different frequencies.
Here, this is more relevant.
Woah woah woah my mom says i overclock quiet well for your information. Ive only seen the magic smoke 3 times =P
bro!! thats the fucking point, the 1600 more times cant reach 4ghz, while the 1600x can reach it more easily
What about this cooler
seems good but i am having a hard time finding reviews of it
I actually dont think it supports am4, it just came up when i typed am4 into amazon. Its an old model I think
found it
Thats super bad (not amazing) and conveniently he has a 1600 for the benchmarks
I think either im going to get the cooler master or the sythe mugen max thing (similar to the H7 but has a backet)
The thing is that it depends when patch of units has arrived to stores warehouse. There are brackets for H7 and such, but if store only has older packages, they aren't included. You can ask from store if cooler has bracket included, if it isn't said directly on product page.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
