Cooler Master - Hyper 212X Dual Fan 82.9 CFM CPU Cooler for 1700x ryzen?
WhiteWulfe
Get a Cryorig M9a, H7, or H5 instead. What is your maximum budget?
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
3 minutes ago, WhiteWulfe said:
snip
Depends if you wanna overclock. I don't particularly like cooler master as a brand, but thats just me.
I agree the 212 is good value in the US, but where I live, stuff that is a good deal better is available for not much more cost.
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
https://pcpartpicker.com/list/vbKLQV
Thats the whole build thus far. So thats cutting my budget pretty close if that tells u anything. :) I wont be OC, if thats the issue with the cpu cooler. And as for liquid cooling, I kind of steer clear of that.
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($289.99 @ SuperBiiz)
Motherboard: MSI - X370 GAMING PRO ATX AM4 Motherboard  ($121.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($126.99 @ Newegg)
Storage: Crucial - MX300 275GB M.2-2280 Solid State Drive  ($99.84 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($66.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB AORUS Video Card  ($708.99 @ SuperBiiz)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.99 @ Newegg)
Total: $1584.66
Generated by PCPartPicker 2017-08-17 23:51 EDT-0400
Total: $1584.66
Theres a slight issue with this. Doesn't OC void warranties for parts and such namely the cpu and even possibly the cooler for the cpu? That's mainly why I wanted the 1700x instead, though that build is damn good, but I also already have a 5tb external I'll mainly be using. Just realized the 1080ti is in that list....wow...Still worried about warranties though...
The chance of you breaking CPU from OC is really low. just stay under 1.41v on Ryzen and u should be good. I would try to keep it under 1.4 or 1.375 tho
Such a damn good build though. Maybe I could take out the HDD possibly, and use that leftover money to make up a bit to get the 1700x
dont lol
You'd need to run some extremely high voltages for really long periods on high loads to break things with OC. If you watch any guide on OC, you won't be hitting those limits.
As for cooler, I would still go for something else than 212. H7 is marginally better, Pure Rock would be best pick from cheap coolers.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
If you lived near a MicroCenter you could get a 1700x for $289.99 + $30 off mobo.
If you're not gonna OC then why not just use the stock cooler. The Wraith Spire even has RGB on the 1700 and should be fine.
|| CPU: AMD Ryzen 5 1600 (@3.9GHz) || Motherboard: ASUS Prime B350 Plus || Cooler: Arctic Freezer 33 eSports Edition || GPU: EVGA GTX 1070 SC || Memory: 16GB G.Skill Trident Z RGB C16 (@2933MHz) || SSD: SanDisk 128GB || HDD: WD Blue 2TB, Toshiba 2TB, Transcend 1TB || PSU: Corsair RM550x || Case: Fractal Design Focus G || Monitor: 2x AOC 23” I2369VM IPS Full HD, Samsung 32" LED TV Monitor || Mouse: Logitech G703 Wireless || Keyboard: Cooler Master MK750 RGB (Cherry MX Brown) || Speakers: Dell Stereo Speakers || Headphones: Sennheiser HD 4.40 BT / Samsung Galaxy Buds ||
CM products are solid i use them frequently a 212 EVO is more then enough you could buy an extra 120mm fan for that it comes with brackets/screws and rubber pads to mount a 2nd fan.
