Dual Cable too Short for Motherboard - Help!
ImAyaanKhan
Hi,
I'm currently building my first PC, and I've come across a hitch. Two of the USB cables are attached to each other (even insulated together, so I can't pull them apart), and I can't attach one without being unable to attach the other.
I've attached pictures below. 5613768960342213278%253Faccount_id%253D3
6780596362606878716%253Faccount_id%253D3
Thanks in advance for the help
Current PC (Second Build) : CPU: Ryzen 5 1600 (OC @3.8GHz, sometimes pushed to 4GHz) RAM: 16gb Corsair Vengeance RGB Pro DDR4-2666 (OC @2733Mhz, sometimes pushed to 2800 for testing purposes)   GPU: PowerColor Radeon RX570 8gb MOBO: ASRock B450m Pro4 SSD: Inland 120gb HDD: 1tb Seagate Barracuda PSU: Cooler Master Masterwatt 500w Lite Case: NZXT H500 OS: Arch Linux+ KDE Plasma [Desktop Environment] & Windows 10 Pro [Broken due to grub 50% of the time]
Accessories: Mouse: Alienware AW958 Elite Keyboard: Corsair K63 Wireless  Headphones: Samsung Level On Pro
Phone (waiting on arrival): Samsung Galaxy Note 9
Potentially, get a different case. If that is not an option, i’d Reccomend plugging the USB 3.0
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
Alright, thanks for the advice. Are there any extensions I can buy to potentially plug in both?
What happened if you plug just the USB3?
I think you can plug just one and have all ports working (since usb are backward compatible).
I think the USB 2 header meant for the motherboard without USB3 header.
Oh, really? That's nice. I haven't finished building the PC yet, I still have to install the SSD and HDD, and fix the cable management, my dad nearly vomited when he saw my current job
If not, you can just get an old header cable from an old case and make your own extension cable.
