Sell 4K 60hz Monitor & GET 34" 144hz Ultrawide Monitor?
11 minutes ago, JDA4Free said:I heard about that. Is the difference between 100hz - 144hz noticable because I really want a 144hz panel that isn't 1080p and small.
3440x1440p it is then.
I personally can see a great deal of difference from 60fps to 80~100fps but past 100ish mark it becomes extremely diminishing. Every one's eyes are different yes but I do think that at 100hz you will have enough butter smooth experience to make the much superior image quality and immersion of a ultrawide worth it.
Both my brother and I went with 3440x1440p, if the flagships with g-sync and 100hz are too pricey LG does feature some awesome 3440x1440p IPS Matte panels that can work as high as 80hz with overclock.
It's up to you but like I said 21:9 is worth it, you get a shit ton of extra virtual space, the screen itself has this extra high end luxury feeling to it, gaming has better immersion, movies on original aspect ratio will fit perfectly no black bars on the bottom, no weird UI scaling that sometimes happens at 4k, you can get browser extensions to make youtube work on 21:9... it's widely supported by now... I think it's worth it... You'll feel tempted to get a more powerful GPU though if you'll play AAA gaming.
