So, long story short, my motherboard is missing a pin or two, from the innermost ring, the most important pins. So, I need referrals to people/companies who you know to be good at what they do, and can get a new socket put on the board, IE BGA reworking. I would just buy a new board, but, that would cost me about $300-$400, as it is a Rampage V Edition 10, LGA 2011-3, since I can’t afford that, I’m looking into socket replacement, anybody here know a guy who knows a guy?
Black Lightning
Intel Core i5-3570K @ 4.7 ghz
Asrock Z77 Extreme4-M
2x8 GB 1600 MHz Crucial Ballistix Sport
MSI R9 290X Lightning
Corsair Crystal 280X Black RGB
240 GB Revodrive 3, 64 GB Sandisk SSD
EVGA Supernova 1200 P2
Noctua NH-C14S
https://linustechtips.com/topic/992065-socket-replacement-referrals/
Well, someone will need a complete set of pins and be willing to solder all of them to the socket. That's not going to be a quick job, which might total more than the board is worth.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
I’ve been told it will cost about $100, but have not gotten any referrals to anyone, a new socket assembly will cost me about ten bucks. Since the board will cost me $450 new and $300-$400 used, I’d rather take the socket replacement route if it’s closer to $100 like I’ve been told.
Black Lightning
Noctua NH-C14S
just send it to ASUS? they might fix it up for you tbh
Builds:
I can try that route, but I’ve never heard of a company doing such repairs on non warrantied hardware.
Black Lightning
Noctua NH-C14S
i havent heard of anyone doing it tbh, they might fix it for some money
Builds:
As Asus is a manufacturer, and not a repair service, I am doubtful, but I’ll look into it.
Black Lightning
Noctua NH-C14S
I used to work at a repair shop and we wouldnt bother repairing the boards if they had more than 10-20 bent pins. I highly doubt you can find anyone willing to do that by hand.
Hes not looking to get the pins repair, but the whole assembly replaced.
@The Blackhat try reaching out to rossman, hes fixed an Nvidia card before... He may do this
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
Thanks, I figured someone knew a company or something who did BGA reworking as a specifically offered service, I can’t imagine soldering a BGA socket with 2011 solder points by hand. Thanks, I’ll look in to them.
Black Lightning
Noctua NH-C14S
Hes re-balled GPUs in macbocks, I'm sure he can do it, its just if he will do it
Thanks, I’ll check in to it.
Black Lightning
Noctua NH-C14S
