By a little, yes. It will cause it to run a few degrees warmer.
https://linustechtips.com/topic/989175-vertical-mount-h500i/#findComment-11913393
1 minute ago, Mugenjynn said:
And a few degrees Celsius is like 900 Fahrenheit
Failed grade 10 math, hey?
https://linustechtips.com/topic/989175-vertical-mount-h500i/#findComment-11913416
You must’ve failed 10th grade English because you don’t know what a hyperbole is ?
Sorry, should have added a /s on there.
You can vertically mount it, it won't matter too much.
https://linustechtips.com/topic/989175-vertical-mount-h500i/#findComment-11913430
9 hours ago, Mugenjynn said:
Will vertically mounting a gpu effect the cooling in a h500i
When using the built in one, Yes. 110%
Native vertical GPU mounts using air cooled cards will almost always put the card WAY too close to the glass, causing the fans not to be able to breathe, meaning higher temps, leading to thermal throttling, ergo loss in FPS.
The recommendation is to use an aftermarket solution like one from @CableMod, CoolerMaster or @Mnpctech which position the gpu properly
https://linustechtips.com/topic/989175-vertical-mount-h500i/#findComment-11914581
13 minutes ago, aezakmi said:
ftfy
ty, much appreciated
https://linustechtips.com/topic/989175-vertical-mount-h500i/#findComment-11916090
