i7 7700k or i5 9600k help what to get
Nicky
I'm planning to upgrade my system with a new processor but idk which one to get
currently I have an i5 6400
I play mostly games and occasionally I stream
any recommendation
Personally, neither.
I would get a Ryzen 7 2700x for gaming and streaming(assuming that's in your budget if you're looking at the 9600K).
6 minutes ago, Finwillwin said:
What is your GPU, you might want to look into a Ryzen 2600?  Intel doesn't offer great price to performance. FYI: Z170 and Z3** don't work together.
i have a NVIDIA GeForce GTX 1060 6GB (MSI)
i7 7700 is cheap and easy to install, and doesn't require much cooling outside of anything that isn't the stock cooler. How much performance do you feel like you need to make up?
Primary PC:
