Yes. Waste of time and money, but you can.
Desktop benching:
https://linustechtips.com/topic/981598-energy-from-heat/#findComment-11842309
Y'all better not be trying to violate laws of thermodynamics by generating some "free electricity" to power your PC.
For real, in some cases a PC is best served as a space heater.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/981598-energy-from-heat/#findComment-11842331
17 minutes ago, lucthesloth said:
I was wondering if it was possible to mod a cpu/gpu heatsink into a thermoelectric generator.
It's possible, but not worth it.
https://linustechtips.com/topic/981598-energy-from-heat/#findComment-11842357
2 hours ago, James Evens said:
yes? but why?
AMD.
14 minutes ago, M.Yurizaki said:
You could probably make a decent sterling engine out of this concept, but don't expect it to be a decent source of extra power.
I might look into this just cuz that sounds fun.
*hopefully doesn’t forget to work on it 10 minutes from now*
https://linustechtips.com/topic/981598-energy-from-heat/#findComment-11842740
Its not a good idea because the thermocouple that generates electricity is intrinsically a thermal insulator, which means itll significantly reduce cooling efficiency and increase processor temps.
A cars exhaust manifold is a better place to use this tech.
https://linustechtips.com/topic/981598-energy-from-heat/#findComment-11842822
