A friend is in need of a PC, which of these builds is better: Intel or AMD?  If you have any improvements or changes you think should be made then let me know, the 212 EVO is unavailable in the UK without paying double it's normal price.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/98156-which-is-better/
for gaming they are on par.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/98156-which-is-better/#findComment-1313063
If so then the Intel build will be the one to get.
https://linustechtips.com/topic/98156-which-is-better/#findComment-1313079
I would personally go Intel because I would make more use of the higher single core performance which will also give you better fps in 95% of games.
That's what I thought as well, I wasn't sure if 8 cores would be better for upcoming games that are using more cores though.  I prefer Intel motherboard a lot more than AMD ones.
Personally I prefer Intel. And as @ said it will perform better.
I think what AMD has going for it is their low budget builds with APU's and such.
True, it seems the Intel build is definitely the one to get.
https://linustechtips.com/topic/98156-which-is-better/#findComment-1313087
The performance increase you would receive from using Intel over AMD is negligible for the price. If you want the extra 5 FPS, get an Intel that is $100 more than an AMD.
I think Intel have much better motherboards than AMD, that was another reason for going with the Intel build over AMD.
https://linustechtips.com/topic/98156-which-is-better/#findComment-1313102
the 8 cores do benefit, but then again the Haswell IPC is so much bigger than FX that it overpowers it. so get intel
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/98156-which-is-better/#findComment-1313103
Yes, upcoming games are starting to use more than 4 cores when they're available, but this is only in the most recent titles, while the list will grow over time, it's not worth sacrificing single core performance for.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/98156-which-is-better/#findComment-1313107
still, intel can substitute less cores by just having them that much faster per clock. so one intel core doing 2 threads is about equal to 2 8350 cores doing 2 threads
https://linustechtips.com/topic/98156-which-is-better/#findComment-1313179
i'd go with the intel
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/98156-which-is-better/#findComment-1313190
What's the system being used for?
Why would you have to pay double for the 212 Evo?
https://linustechtips.com/topic/98156-which-is-better/#findComment-1316774
Mainly for gaming and the EVO is out of stock everywhere.
https://linustechtips.com/topic/98156-which-is-better/#findComment-1317647
Edits: http://uk.pcpartpicker.com/p/2wutu
https://linustechtips.com/topic/98156-which-is-better/#findComment-1317747
Its not on amazon.
It was being sold for £25 and £10 postage but Amazon now have it in stock for £26 and free postage, they weren't selling it themselves yesterday.
https://linustechtips.com/topic/98156-which-is-better/#findComment-1318148
Prices change daily.
https://linustechtips.com/topic/98156-which-is-better/#findComment-1318185
