Kingston FURY 8GB 2400MHz DDR4 CL15 DIMM 1Rx8 HyperX FURY Black        ( 8 more gb soon )
Intel i5-8400 2.8-4.0 ghz
GTX 1060 6gb
HDD 1TB WesternDigital
MB Gigabyte H310M   or will go with b360m
Monitor 22" Philips 223V5LHSB2/00
Kingston 120gb SSD
Can u guys help me pick a psu out of the pictures i provided cuz those are only available in my country? also be reasonable with price (the higher the ден. is the more expensive it is)
image.png.84c8edbaff2bdf608a2f0c4a113ccf43.pngimage.png.c6feca0f14762ee4a27085d243964d3a.pngimage.png.c6feca0f14762ee4a27085d243964d3a.pngimage.png.cda8095eb84b4205422665ad4a35eaef.pngimage.png.705885cb2dcfa054d0768aaa4a37f5a3.pngimage.png.5036109e981d5930f29abe278b522636.png
https://linustechtips.com/topic/972634-help-me-pick-a-psu/
EVGA 450 BT sounds good to me, a GTX 1060 doesn't need that much power.
Although, in the big picture, most if not all of these look garbage.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/972634-help-me-pick-a-psu/#findComment-11759255
Take a look at the PSU tier list.
No brand is "safe" for bad PSUs.
You could also save cash by grabbing a RX 580 8GB instesd of the 1060. It is often cheaper than the 1060 and performs the same.
Also an r5 2600 and a B450 PRO4 or Tomhawk board is probably cheaper
https://linustechtips.com/topic/972634-help-me-pick-a-psu/#findComment-11759260
It doesn't look like those are the only PSUs available, but rather the PSUs that you consider cheap enough. That, or every single PC build in your area uses super low end PSUs.
Edited by seon123
Something something
https://linustechtips.com/topic/972634-help-me-pick-a-psu/#findComment-11759266
CoolerMaster Elite 500W or the EVGA B450 i guess?
Builds:
https://linustechtips.com/topic/972634-help-me-pick-a-psu/#findComment-11759273
7 minutes ago, Bananasplit_00 said:
8 minutes ago, seon123 said:
12 minutes ago, seoz said:
15 minutes ago, Firewrath9 said:
16 minutes ago, Merciless said:
By quite a long shot, the Deepcool DQ-ST is definitely the best of those units. It's not even comparable to most of those.
https://linustechtips.com/topic/972634-help-me-pick-a-psu/#findComment-11759292
14 minutes ago, Firewrath9 said:
ha ha elite is tier 7 on the LIST
i legit just picked it because its a name brand tbh but our PSU god has spoken so Deepcool DQST should be the best then
Builds:
https://linustechtips.com/topic/972634-help-me-pick-a-psu/#findComment-11759392
I'm not PSU god :P
There are definitely people on the forum that know more than me! I mean JonnyGURU uses our forum frequently...
https://linustechtips.com/topic/972634-help-me-pick-a-psu/#findComment-11759413
1 hour ago, STRMfrmXMN said:
I'm not PSU god :P
hey you are the one i see helping the most people xD i think you deserve it
Builds:
https://linustechtips.com/topic/972634-help-me-pick-a-psu/#findComment-11759677
Nah, I barely even comment anymore :P I just don't have the time I used to as I work at a car dealership now and the hours are just terrible in that industry...
Usually I just like Stefan Payne's or seon's posts and leave since I'm too damn tired to write much up in anything but a grumpy mood.
https://linustechtips.com/topic/972634-help-me-pick-a-psu/#findComment-11759697
