Safe to use power supply mobo extension cable?
Solved by Spotty,
What motherboard do you have? What CPU cooler? The CPU fan shouldn't be anywhere near close enough to the motherboard 24pin connector for it to get in the way (if anything, the RAM sticks will block the cooler/fan first).
I will not recommend using extension cables for your PSU. Especially not cheap $2 generic garbage made in china for half a cent like the one pictured.
If you are going to go with the CableMod Cables as others have suggested, then if anything you should get compatible replacement motherboard cables since you have a fully modular PSU, not extension cables.
