Posted September 14, 2018 I've been looking into buying a mechanical keyboard for a while now and think I would like MX Blues the best because I like the clicky sounds and care more about typing because I'm not really a competitive gamer. The only potential issue I can see is the level of noise of the keys, as I live in a house in close proximity to other people and don't want them wanting to kill me every time I go to type something. I'm currently using an old Logitech G15 keyboard (I think second gen, whichever one has the orange LCD screen) and am a fairly heavy typer to begin with if that is any comparison for noise levels, and am thinking about getting the Corsair K70 LUX keyboard. Also, if anyone knows a store where I could go to try typing on a mechanical keyboard in the Phoenix (AZ) area please let me know. Thank you for any help you can offer! Edit: Also, has anyone used the K70 with OSX (*cough* hackintosh *cough*)? I would assume they'd be compatible but I just wanted to check. Intel i7-8700K | GTX-1070Ti | LG 34UC80-B | 32GB DDR4-2400 | Corsair SPEC-03 | WD Black 256GB M.2 SSD & Toshiba P300 3TB 7200RPM HDD | ASRock Z370 Killer SLI/ac | Corsair TX550M | Cryorig H7 | Logitech G15 & G500S | Windows 10 Home & OSX 10.13 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2018 Blue switches are pretty loud, they do sound decent and have decent keyfeel but if you type decently fast then you are in for a lot of sound I spent $2500 on building my PC and all i do with it is play no games atm & watch anime at 1080p(finally) watch YT and write essays... nothing, it just sits there collecting dust... Builds: The Toaster Project! Northern Bee! The original LAN PC build log! (Old, dead and replaced by The Toaster Project & 5.0) Spoiler "Here is some advice that might have gotten lost somewhere along the way in your life. #1. Treat others as you would like to be treated. #2. It's best to keep your mouth shut; and appear to be stupid, rather than open it and remove all doubt. #3. There is nothing "wrong" with being wrong. Learning from a mistake can be more valuable than not making one in the first place. Follow these simple rules in life, and I promise you, things magically get easier. " - MageTank 31-10-2016 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2018 Author Okay, do you know if MX Browns having any audible feedback that is quieter than the blues? Intel i7-8700K | GTX-1070Ti | LG 34UC80-B | 32GB DDR4-2400 | Corsair SPEC-03 | WD Black 256GB M.2 SSD & Toshiba P300 3TB 7200RPM HDD | ASRock Z370 Killer SLI/ac | Corsair TX550M | Cryorig H7 | Logitech G15 & G500S | Windows 10 Home & OSX 10.13 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2018 Just now, aleksfacco said: Okay, do you know if MX Browns having any audible feedback that is quieter than the blues? The Browns don't really make much of a clicky sound, though it will make a sound if you bottom it out. And it's much less tactile. For more tactile tactile switches, there's things like Zealios, Zilents and Box Royals. I think Matias also has some tactile switches. :) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2018 The force used in typing also affects how much noise it makes, since hitting the bottom of the keystroke also produces noise CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2018 Author Okay, I might want to consider the browns then because based on my use of my g15 I will probably be bottoming out the keys (it also helps that the brown version is on sale on amazon right now). Intel i7-8700K | GTX-1070Ti | LG 34UC80-B | 32GB DDR4-2400 | Corsair SPEC-03 | WD Black 256GB M.2 SSD & Toshiba P300 3TB 7200RPM HDD | ASRock Z370 Killer SLI/ac | Corsair TX550M | Cryorig H7 | Logitech G15 & G500S | Windows 10 Home & OSX 10.13 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
