Ryzen 5 2600 Overclocking Help
Solved by GoldenLag,
the base voltage should be visable in the BIOS, set the offset accordingly
use Ryzen master to play with Voltage and stability. anything below 1.42 is safe voltage, though for your mobo 1.38 and below is probably where you should be playing. start at 1.32 and work you voltage up untill you hit a stable 4.1 ish ghz or whatever your target frequency is
Edit: when you have found the stable voltage, then apply in BIOS.
