Need Help Finding A M.2 to USB Case
Yayap7
Hey,
So I am wanting to update the SSD that is in my 2016 Razer Blade 1060.  It has the Samsung PM951 NVMe SSD in it and I am wanting to replace it with the 970 Evo M.2.
-that is possible, correct?
And 2, I then will want to make the old M.2 a USB drive.  The thing is, I cannot find any compatible case or enclosure for it that is less than $50..
Does anyone know of a solid m.2 to USB 3 enclosure that is compatible with the M Key?
Not the B Key, not M and B Key,  just the M Key
(PCIe)
-as far as I can tell.
Thanks!
--Desktop--
Vanya
MSI B550M Pro-VDH WIFI
AMD Ryzen 5600X
Radeon RX 6600TX
G.Skill TridentZ Neo DDR4 3600Mhz  16 x 2
1: Yes. The new SSD will fit.
2: This USB enclosure will work. However it's not Thunderbolt 3.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
Well that's disappointing.  You can get a SATA M.2 enclosure for $30 but NVMe is behind and still expensive at the moment.. rats.
Well if anyone knows of any solid and cheaper M.2 NVMe to USB enclosures out in the wild,  I'd love to check it out.
Don't want to not be able to use that replaced SSD..
--Desktop--
Vanya
AMD Ryzen 5600X
Radeon RX 6600TX
