PSU Cable to CPU is Different!
roy12
The power supply that I bought has a CPU plug that is completely different to my mobo CPU plug, do I have to buy another PSU now since it doesn't fit into it?
What PSU and what motherboard?
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
Asus ROG Strix Z370-e Gaming mobo
EVGA BR 700W PSU
EVGA BR 700W PSU
Are you confusing a PCIe power for the 12v EPS cable? That's all I can think of.
Yours faithfully
No, on the plugs for power to CPU its says "CPU" I made sure to check every singe plug that said "PCI-E" and split them apart, then tired to plug in but none worked.
Sigh....
You need to join the two CPU 4 pin connectors together then plug it in.
1 minute ago, TrigrH said:
Sigh....
I did, but the pattern doesnt match.
The patterns does not need to match, the shape of the holes is different.
As long as it is a CPU/EPS connector you can plug it in.
Yes you need both the 24 pin and 8 pin CPU to the motherboard.
Yes it does
24-pin, 4+4-pin - these ALL ATX SYSTEMS USE
So your PSU has the connections. Just need to use the right one.
turn it around..
That doesn't work it wont click on, either way, the pattern doesnt match at all.
Pack all of your components up.  Return them.  Order a PC from Dell.com.
  • 1 year later...
Ok so if I got this right. The shape doesn't match the hole but that is what the psu seasonic gave me and its labeled cpu on one end and psu.
I put the psu on the psu lol and the non matching shape marked cpu i plug that on the only 8 pin connector there is on the MOBO aka (cpu 8pin)??? Is that right?
Thank you soo much i am a big noob and i know you just answered the qs but i want to make sure that I uNDERSTOOD YOUR ANSWER.
Yes that is right :)
