GPU could not fit in my case.
Mr.Mago
Hey, I just ordered a Zotac gtx 1080ti AMP! edition which measures 300mm lenght. and my case has only 295mm space for gpu's. Will this be a problem? will it touch the drive bays ? my case is the AeroCool Strike-X Advance.
ok.....
you have the gpu and the case.... how about YOU tell us if it's too big or not.
or did you want one of use to order the case and gpu and find out for you before yours arrives?
There's a reason for length measurements in GPUs and GPU space for cases. It doesn't look like those drive bays are removable. I doubt it will fit, unless you cut out part of the bays or drill out the rivets and remove the drive bays completely. Or... get a different case.
i5-8600k delidded + Conductonaut - msi Z370-A Pro - Corsair Vengeance LPX 3000 2x8GB - be quiet Dark Rock 3 - Zotac GTX 1070 mini
Meh.
The 295mm spec assumes you're using the 3.5" hdd mounts. If you don't use the mounts directly in front of the card, it should fit fine.
There are no physical drive bays in this case. The mounts are "tooless" and have nothing surrounding them when not in use
https://www.youtube.com/watch?v=myS3bC6BvdM
So the GPU will fit, it will just have to be maneuvered into around the front HDD plate
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
