Advice please!
We all go for the highest MHz with memory but I feel the latency is probably as important if not more important.
So with that in mind what is the lowest latency DDR4 memory on the market?
I have 16gb of Corsair LPX Vengeance 2400MHZ and 8gb of Corsair LPX Vengeance 2666MHZ. So basically 24gb running at 2400MHZ.
I realisticly don't that much.
So I'm thinking of selling it all and buying 8gb of the best money can buy.
Just looking for peoples opinions on this and recommendations for super low latency and super high frequency memory.
Thanks in advance
https://linustechtips.com/topic/960246-memory-for-the-speed-junkies/
Don't forget about bandwidth, but yeah I love me some low latencies. I am running the G.SKILL TridentZ 3600CL15 2x8GB kit. I got it at $263 but have seen it as low as $235.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
but isnt 8GB too little? 16GB should be better.
Also, fast memory for showing off, benchmarks or price to performance?
Desktop benching:
Also don't forget you want two sticks for dual channel.
You're looking for anything with good Samsung B-die. Most kits that are 3200MHz CL14 are.
https://benzhaomin.github.io/bdiefinder/
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
Here's how latency in milliseconds is calculated:
latency multiplier * (1/(clock speed/2))
lower latency is achieved by higher frequency, so with cas15 on a ddr4 3200 chip, you have 15*(1/(3200000000/2)) which is .00000000938
with cas 12 on ddr4 2600, you get 12*(1/(2600000000/2)), which is .00000000923
in this case, you can see the 2600 only has a slight advantage, so lowering latency on a high clocked dimm rather than raising frequency on a lower latency dimm might be easier.
Primary PC:
PSU tier list
How many watts do I need?
I would like to think I'm a little more advanced than your normal computer gamer/general bulider but unless I'm not reading this right to get a comprehension of a hat you're saying this might be a littk advanced fo me. Could you explain in less advanced terms?
math says cl12 2600 is as fast as cl15 3200 in terms of column access (cas stands for column access strobe.) latency in real time is therefore almost the same on those 2 kits of ram, despite their wildly different specs. taking a cl15 dimm down to cl14 in bios seems easier than taking 2600 ram to 3000, depending on die quality of course.
Primary PC:
PSU tier list
Right I understand. Thank yiu
